Old 03-13-2013, 04:28 PM   #1
dirtracer81_2
Confused camaro front rotors!!
Ok im stumped need some help here....
Have an 81 c10 frame under my 57 with a camaro rear. Looking to get matching lug patterns and wheels are easier to come across...
Ok heres my thing what rotors do I go with? I tried looking some up and they make so many different types. Anyone know what to do here?
dirtracer81_2 is offline   Reply With Quote
Old 03-13-2013, 04:42 PM   #2
Ziegelsteinfaust
Re: Confused camaro front rotors!!
McGauheys, and CPP both have conversion rotors.
Or if your rotors are good you can have them re-drilled cheaper.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-13-2013, 04:59 PM   #3
SCOTI
SCOTI's Avatar
Lt Duty (1" vs 1.25" thick rotor) C10 brake systems will allow the Camaro front rotors to interchange It requires the lt duty spindle, rotor, & caliper.
If you have the 1.25" thick rotor combo, it might be cheaper to re-drill or purchase rotors set-up w/the car pattern.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-13-2013, 06:22 PM   #4
dirtracer81_2
It does have the 1" rotors
Old 03-13-2013, 07:39 PM   #5
LynnJr
Dirtracer81_2
The Camaro front rotors are all different.The bearings are all different.The seals are all different and the lips that hold the grease caps over the bearings are different.
The best way to go about it is to go to the closest auto supply store full of teenagers and pick up a rotor.Now take it home and see if it fits and take note of what doesn't fit.
Now go back to the auto supply house and get one that better matches up.
After you repeat this process 3-4 times your all set.
I did this at a wrecking yard one day and spent the whole afternoon turning rotors.The guy at the wrecking said hey what are you trying to pull here so I explained to him that all the old rotors were turned with new bearings in them and that he kept selling me the wrong part and all was good.
LynnJr is offline   Reply With Quote
Old 03-13-2013, 09:35 PM   #6
SCOTI
SCOTI's Avatar
Ask for 1LE rotors for a 88-92 Camaro.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-14-2013, 02:54 AM   #7
74 stepside
74 stepside's Avatar
Originally Posted by LynnJr View Post
Dirtracer81_2
Are you serious?? You must have alot of time on your hands...
74 stepside is offline   Reply With Quote
