Old 03-14-2013, 07:45 PM   #26
j.kirn
Re: 1999 silverado
Originally Posted by clinebarger View Post
Best advice anyone can give!!!
thats been tried as well, iguess ill figure it out soon or later
j.kirn is offline   Reply With Quote
Old 03-14-2013, 08:33 PM   #27
Boog
laying low
Boog's Avatar
Re: 1999 silverado
You mentioned having a K&N air filter. You oil those routinely. You might try cleaning the MAF sensor. Sometimes air filter oil will get on the sensor and cause some issues.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-14-2013, 08:58 PM   #28
Sooner84
Sooner84's Avatar
Re: 1999 silverado
I was going to say the same thing. A dirty MAF will cause all sorts of problems, especially stumbling at idle or driving.
1984 chevy swb(1st truck, sold..)
2001 RCSB silverado, 5.3 with a little extra
2004 ECSB Silverado LT, 5.3 cam & bolt ons, 4l60e shift kit/stall, g80 & 3.73s
My first (1984 c10) Build
Sooner84 is offline   Reply With Quote
Old 03-14-2013, 11:21 PM   #29
j.kirn
Re: 1999 silverado
this puppy gets high maintenance and yes those are kept up to and not the problem
Old 03-15-2013, 12:21 AM   #30
Black 'n' Blue
Black 'n' Blue's Avatar
Re: 1999 silverado
I've noticed that you said "told" they were good. Is there any way you can check for your self? Not saying your mechanic is screwing you over, but it has happened before. If the fuel PSI is good, I would pull the MAF off clean it. If that does not work, possibly the air filter is gone? Can you describe the stumble? Is it a heavy stumble where it feels like the truck is hitting a wall, or is it a subtle stumble? Also, you didn't happen to incorrectly adjust the elevation on the computer? I am not familiar with that chip, and what it offers.
-Justin.
The past cannot be edited, or erased. Only accepted.
Loud, proud and country by the grace of god!
Bradley Anderson 1997-2011
Black 'n' Blue is offline   Reply With Quote
Old 03-15-2013, 12:40 AM   #31
j.kirn
Re: 1999 silverado
mainly say doing 60 then press pedal to floor then it has a hard stumble. when you let off a bit its ok. i clean the kn airfilter every year and the air flow sensor gets cleaned while im at it with the correct cleaner. i guess i need to check the fuel pressure myself but like i said it did this with the original pump to
Old 03-15-2013, 12:42 AM   #32
j.kirn
Re: 1999 silverado
would the fuel pressure regulator cause this
Old 03-15-2013, 12:47 AM   #33
Black 'n' Blue
Re: 1999 silverado
Yes it can. These truck are known for bad fuel systems. Well every truck I've worked on has.
-Justin.
