Easiest way to replace a door hinge pin?
The top passenger hinge pin broke. My door was starting to sag, and then it gave away all together, and was only held by the bottom hinge.
So, I found a good replacement hinge at the yard today. I was thinking if I just replaced the pin that the replacement hinge came wit, it might be easier than the whole hinge. Any tips for how to do this, or do I need to just replace the entire hinge? The truck I got it from was missing the front fender. I really hope I don't have to remove the fender to replace the hinge... Posted via Mobile Device |
![]() Join Date: Jul 2007
Re: Easiest way to replace a door hinge pin?
U can change just the pin but it might be tough to dO on. You don't need to remove the fender to get the hinge off. Get after it. Shouldn't be that tuff either way
Phil '70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver '72 short super build 4wd '72 Suburban LT4 coming soon!! |
I think it would be tons easier just swaping the whole hinge...
#4 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Ledd Zepp, I get the willies everytime I see your new avitar
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Quit if it's not FUN!!!
Easy to change if you take the whole door and hinge off together. Don't forget to mark the location on the door jamb and get some help. These old doors are heavy. Once the assembly is off, you can change the pins with no sweat.
![]() Join Date: Sep 2009
just replaced the pins and bushings on my driver door. wasn't hard at all but did have to take the door off of the hinges then drove the pins out, new pins and bushings in and re-hung the door.
It didn't make the difference I hoped for on my doors but if yours is broken then it is an easy fix for $10 |
Cluster King
Cluster King
Yes, much easier to replace the whole hinge but not bad to do pin and bushings.
#10 | |
If it is bad enough to have fallen apart, I would replace the whole hinge. I have seen them worn so badly the the bushing was totally gone and starting to wear out the hole that it fits into.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Thanks for all the help guys. This was a giant pain in the a$$. Wow, you wouldn't think it, but it was on par with something like maybe changing the dash pad.
I decided to just replace the whole hinge and pin. The best way was to unbolt everything from the hinge on the door side, and then remove the door. Then I could get easier access to the bolts on the body side of the hinge. By the way, this is a two man job. Notice I said MAN. Somebody needs to hold the heavy door, while someone bolts it on. Adjusting the door to shut was a real pain. I ended up having to buy a new set of wrenches at harbor freight, so I could gain access to the body side bolts, once the door was on. Here's the wrench I got ![]() Anyway, it's all buttoned up and works great now Posted via Mobile Device |
x3
I'm not trying to hijack this thread but a ledd zepp avatar pole? Handsome? Hilarious? Or just plain creepy?
Anywas Mister-B I found this thread helpful. Thank you. Posted via Mobile Device
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
#15 | |
#16 | |
Moderator
#17 | |
No cherry picker...did you do the work in a garage? With exposed rafters? Those cheap ratchet straps, or a come-a-long, over a rafter help w/the weight. Then all you gotta do is move it into place. I've even used a tree branch w/no garage. Play safe....don t. .... |
#18 |
Lol glad you got it fixed, yes those style ratchet wrenches will always be handy
#19 |
When I take the doors on and off, I use my motorcycle jack under the door with a block of wood. I can set the height exactly where I need it and roll the door into place. Makes it a reasonable one-man job.
http://www.sears.com/craftsman-profe...p-00950191000P
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#20 |
I used a cooler with a blanket folded up on top of it to get the right height and the wife helped balance it until I got a couple bolts in.
They are heavy for sure. I find myself checking the space around everyone else's doors. I have yet to see one with perfectly even space around the door. I have come to realize that its just one of the many characteristics of our trucks. I picked up a new inner front fender yesterday at the Myrtle Beach car show. I haven't looked it over yet, but I'm hoping I can leave the outer fender and hood in place and not remove all that to swap it out. The old one is rusted out directly below the battery.
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! ![]() |
#21 |
Those are good ideas on how to do it without a helper.
#22 | |
