Old 03-17-2013, 08:20 PM   #1
Bwake
Crazy fuel consumption!
I just bought a 61 Apache10, 235 ci that hasn't been driven in a long time. I put 2 1/2 gallons of clean gas in the truck to get it home. The truck idled okay but ran very sluggish, poor acceleration. I had someone following me that said they smelled gas pretty bad. When I got home I noticed that the inline fuel filter had quite a bit of rust in it so I pulled the gas tank. The crazy thing is there was only about 1/2 gallon of gas in the tank of the 2 1/2 gallons I put in. I drove less than 20 miles and burned almost 2 gallons of gas. What the heck is going on? There are no obvious leaks. I don't smell any gas while the truck is parked. It has to be more than rust in the tank!
Bwake is offline   Reply With Quote
Old 03-17-2013, 08:52 PM   #2
gbrown
gbrown's Avatar
Re: Crazy fuel consumption!
If you went 20 miles on 2 gallons of fuel, you're not far off from average fuel mileage for these trucks. Or so I've been told. I'm working on a 60 Apache with the 235 and it sure is thirsty! I'm hoping a thorough tune-up will get my mileage up into the teens. Good luck.
gbrown is offline   Reply With Quote
Old 03-17-2013, 09:02 PM   #3
Jackjohn
I've got a 66 with a350, auto, and 308 rear. I get 9 to 10 in town, almost 14 on the hiway! Woohoo!
John
Jackjohn is offline   Reply With Quote
Old 03-17-2013, 09:08 PM   #4
Bwake
I guess I just thought a 6 cyl with a little carb would get better milage!
Old 03-17-2013, 09:19 PM   #5
hopped up
hopped up's Avatar
The 6 banger gets the same if not less mpgs. But I get around 12 with a 350
hopped up is offline   Reply With Quote
Old 03-17-2013, 09:49 PM   #6
Bwake
Wonder why my buddy who was following me could smell gas? Just running rich?
Old 03-17-2013, 09:54 PM   #7
gbrown
gbrown's Avatar
That would be my guess. If you plan on driving this truck often, you might consider replacing your 3-speed with a T5 from an S10. I haven't done this yet myself, but I will as soon as I am able. I've been told (and hope it's true) that you can expect mileage in the teens after making this swap.
Old 03-17-2013, 10:05 PM   #8
Clyde65
Clyde65's Avatar
It could have leaked out some, that old rubber is prolly cracked and such.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-17-2013, 10:40 PM   #9
Bwake
Thanks for the input guys. I'm probably going to tune it up and either clean or replace the gas tank. I'm used to the days when you could put $12 worth of gas in and drive all week. $12 ain't much gas today!
Old 03-17-2013, 10:44 PM   #10
joedoh
joedoh's Avatar
rebuild the carb, the gaskets were probably shot and you were pouring gas through the carb by the bucketload.
Old 03-18-2013, 10:38 AM   #11
gbrown
gbrown's Avatar
^^^Both of these guys are right. ^^^ Such was the case on mine.
