Old 03-03-2013, 01:19 PM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
Unhappy front end problem help!!!!!!
Ok so i have a 95 1500 2wheel drive lowered 2" by spindals the other day on my way to work my drivers side lowerball joint broke so i figured time to replace some stuff so i bought inner outer tie rods upper ball joints new shocks and new lower contol arms with ball joints so i just got finished redoing the drivers side stuff now it seems like it sits way higher up than the other side is it because of the new parts on one side compared to old now im just kinda worried maybe the spirng isnt sitting in the pocket right was a real pain in the but to get it all back in what do u guys think
1987 m1028 cucv d30
2001 chevy s10
2000 honda shadow sabre 1100
"it's going to be an interesting ride home"
81ratrodc10 is offline   Reply With Quote
Old 03-03-2013, 06:04 PM   #2
dragginmetal
here, just not logged in
dragginmetal's Avatar
Re: front end problem help!!!!!!
It could be the spring. You should be able to see if it is in the LCA right. Look at the shock and make sure its in the center of the spring all the way up. I bent the fingers on the piece that the shock bolts to at the top trying to remove the spring the first time. The spring wouldn't seat at the top right. The spring looked right, but you could see the shock wasn't in the center of the spring closer to the top. The truck sat around 1/2" higher on that side because of it.
dragginmetal is offline   Reply With Quote
Old 03-04-2013, 04:16 PM   #3
81ratrodc10
house of chevy's
Did u have to take it all apart to fix it or
1987 m1028 cucv d30
2001 chevy s10
Old 03-04-2013, 04:27 PM   #4
dragginmetal
Yes. It all had to come apart again. I had to lay on my back to see up in the spring pocket. Then use a hammer and prybar to straighten 2 of the fingers.
Old 03-05-2013, 06:36 AM   #5
81ratrodc10
house of chevy's
Im hoping its just new parts id really hate to take it apart again as i still have the whole other side to do still how did u remove and reinstall the spring with a compresor tool or
1987 m1028 cucv d30
2001 chevy s10
Old 03-05-2013, 09:57 AM   #6
dragginmetal
I use the jack under lower control arm method.
Just another idea. Did you "load" the suspension when you tighten the control arm bolts? If you tighten them with the suspension hanging it might be holding that side up... I'm just shooting in the dark here.
Old 03-05-2013, 10:04 AM   #7
81ratrodc10
house of chevy's
Wow i did tighten them up without weight on them i never even thought of that have to look at that too i guess im hoping weather here isnt bad so i can hit it again on sat
1987 m1028 cucv d30
2001 chevy s10
Old 03-17-2013, 11:21 PM   #8
dragginmetal
Just curious, did you find the problem?
Old 03-18-2013, 05:01 AM   #9
81ratrodc10
house of chevy's
Well i spent sat replacin all the stuff on the pasenger side and it sits the same heigjt now as driver side so not to sure
1987 m1028 cucv d30
2001 chevy s10
Old 03-18-2013, 05:28 AM   #10
81ratrodc10
house of chevy's
Just seems like it sits high in the front now havnt been able to drive it still i broke a bleeder on the caliper so gotta try and get that out before i buy a new one
1987 m1028 cucv d30
2001 chevy s10
