Old 03-21-2013, 12:53 PM   #1
ubtripn
ubtripn's Avatar
What can cause an uneven truck?
When the springs and shocks are new. I still have a one inch difference in height on the left side. Could it be the rubber cab mounts?
ubtripn is offline   Reply With Quote
Old 03-21-2013, 12:55 PM   #2
RHGuyettejr
RHGuyettejr's Avatar
Re: What can cause an uneven truck?
Could be cab mounts either the rubber is deteriorated or rust has gotten to them. probably the most common way to make a truck sag. Measure the height to the frame on each side and go from there, also inspect your body mounts.
RHGuyettejr is offline   Reply With Quote
Old 03-21-2013, 01:01 PM   #3
ubtripn
ubtripn's Avatar
Ok, thanks. Are cab mounts very hard to replace?
Old 03-21-2013, 01:04 PM   #4
RHGuyettejr
Ive never done it on one of these older trucks. My understanding is there are rubber bushings set up as spacers, youll have to jack the cab or bed up to replace them, if it is the metal mount coming off the frame you can either weld in new ones from a supplier or LMC sells slip on ones, still think you need to weld them if they are not too far gone. If your truck is relatively rust free it's probably the bushings. If it is the bushings, then I would replace them with some prothane ones if available they will last longer. Pretty sure summit sells the kit to do them all pretty cheap.
Old 03-21-2013, 01:38 PM   #5
cdowns
cdowns's Avatar
very common for chevy trucks is a twisted frame due to a long hard lifespan of hard use as a truck
Old 03-21-2013, 03:37 PM   #6
buckskins4ever
buckskins4ever's Avatar
Cab mounts arent too bad to replace. But my question for you is...Are you measuring ride height at fender openings or just by the cab rockers? If measuring by cab rockers, you can start with your cab mounts. But cab mounts wont cause suspension height differences at your fender wells. Even with new springs and shocks, you could have a twist in the frame a bit...not much so that you will notice driving, but 1 inch would def lead me there if measuring by fenders.
buckskins4ever is offline   Reply With Quote
Old 03-21-2013, 04:45 PM   #7
ubtripn
ubtripn's Avatar
Thanks all. It is the heaight of the ground to the bumbers. I am going to check all of the mounts and spacers now. (Thx for the info on where to get them.)
I sure hope its not a twisted frame.
Old 03-21-2013, 05:27 PM   #8
jhwkns
Registered Cruiser
jhwkns's Avatar
^^^ this ^^^
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 03-21-2013, 06:00 PM   #9
chasinhiway
chasinhiway's Avatar
If your measuring at the bumpers then the cab bushings wont effect it. the bumpers bolt straight to the frame.
chasinhiway is offline   Reply With Quote
Old 03-21-2013, 06:01 PM   #10
leddzepp
Moderator
leddzepp's Avatar
x 3.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-21-2013, 09:42 PM   #11
doc74021
I just sent my 69 stepside to the frame shop because it was hit 30 years ago and the bed sagged on drivers side
doc74021 is offline   Reply With Quote
Old 03-21-2013, 10:03 PM   #12
brad_man_72
the boat guy
brad_man_72's Avatar
New springs.... are they clocked right in the lower control arm? Are they specific for each side?
Do the springs match? One of the new shocks could be blown. Bent frame, bent sway bar. Bushings binding.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-21-2013, 10:13 PM   #13
RHGuyettejr
Sorry, didn't know you measured at the bumper. Probably not a cab mount issue then, because as stated the bumper mounts to the frame. I would measure rocker to ground and frame rail to ground to eliminate it possibly being just a skewed bumper. If the frame checks out with the same measurements on each side its a bumper mount issue. If not check the installation of new hardware as stated. Also have you had any trouble getting it aligned? Could be skewed a-arms or such. Unfortunately these trucks usually got used for trucks, and after a long hard life the frames can get sprung naturally from having loads etc, or even accidents. Hope you figure it out.
Old 03-21-2013, 11:23 PM   #14
Sklptrljay
Sklptrljay's Avatar
Look for a low/high spot in the frame rails. If you can find it, try placing a jackstand in the appropriate spot on the frame overnight and see what happens. You would be surprised what a little gravity can do.
Sklptrljay is offline   Reply With Quote
Old 03-21-2013, 11:33 PM   #15
TBONE1964
Cluster King
TBONE1964's Avatar
In case it has not been mentioned, shocks have no affect on ride height. The job of a shock is to control the action of the spring.
It sounds like you need to get to a frame shop and have them check for twisted or bent rails.
TBONE1964 is offline   Reply With Quote
Old 03-21-2013, 11:53 PM   #16
brad_man_72
the boat guy
Shocks are pressurized and want to be in the extended position, if a shock is blown it won't be applying the same pressure as the other new shocks and could cause uneven height.
Shocks can also sieze and bind which would cause an uneven ride height.
So no a set of good shocks won't effect ride height much a set of bad shocks can greatly effect ride height. New parts aren't always good.
Old 03-22-2013, 12:28 AM   #17
tcoop68
tcoop68
tcoop68's Avatar
You could have one spring weaker than the other front or rear can affect it. Cheap fix.
tcoop68 is offline   Reply With Quote
Old 03-22-2013, 12:52 AM   #18
TBONE1964
Cluster King
TBONE1964's Avatar
If you want to make sure that shocks are not the problem then take them off and see if that corrects the problem. I have never seen a shock, gas pressurized or not override the weight on a spring.
Old 03-22-2013, 01:45 PM   #19
ubtripn
ubtripn's Avatar
I will re-measure. It had the same tilt before I put new springs and shocks on so that should help narrow it down. Thanks everybody.
Old 03-22-2013, 01:57 PM   #20
brad_man_72
the boat guy
I've had a shock bend and sieze it effected the ride height, it was holding the car up instead of the spring.
Since this isn't a new problem its probably the frame and not one of the new parts.
Old 03-22-2013, 02:18 PM   #21
dmw319
Mine sags on the left also about an inch. Its called "chevy lean". Do a search on here and youll see tons of threads about it. One way to fix it is to add shims to the lower side or just leave it as is! (What I did)
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 03-22-2013, 02:25 PM   #22
67ChevyRedneck
67ChevyRedneck's Avatar
^ My S10 had the same issue. The ps was 3/4" higher than the driver side (or vice versa can't remember)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-22-2013, 03:19 PM   #23
JointTech
JointTech's Avatar
fat butts cause this. My granmothers car was always tilted to the drivers side. she had a big butt.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 03-22-2013, 03:37 PM   #24
ubtripn
ubtripn's Avatar
Lol-ok, thanks all.
Old 03-23-2013, 12:27 AM   #25
KrazyRay
KrazyRay's Avatar
I had the same problem a few years ago. They told me that it was the fat driver!
KrazyRay is offline   Reply With Quote
