Hub Centric Rings
So I need a little education - looking to do some smoothies on my 64 stepside.... so I guess I need Hub Centric Rings - I've never dealt with these - has anyone used these - and does any have insight into how you measure for these... completely outside my comfort zone here. Thanks
64 Step Side - The Mistress |
![]() Join Date: Oct 2006
Re: Hub Centric Rings
hub centric rings help to center the wheels on the hubs. what type of smoothies are you going with ? Chances are you can get by with out the rings.But if you develop a vibration you can use an E.T. style lug nut.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
looking to run some centerline smoothies - I love the look of these
http://www.jegs.com/i/Centerline-Whe...56656/10002/-1 and I can't stand trying to keep chrome on wheels looking nice and figure these are a quick clean
Nice lookin' wheels. Too bad the hub is too small!!
wouldn't something like this work though -
http://www.jegs.com/i/Centerline+Whe...56655/10002/-1 a bunch of guys run these on our trucks... right?
Yes those will work. THe other ones in your other link didn't.
![]() Join Date: Oct 2009
not being hub centric on a hub-centric truck with a lug-centric wheel is ok if the hub opening is too large (C/K20 guys do it often by using Ford 3/4 ton wheels on our 3/4 ton trucks). But a too small hub opening is a no-go.
#8 | |
if its 5 lug its a 3 in bore , if its a factory drums its 3.5 , the larger bore center ones
will work but the caps are horriable , i suggest machining the hubs down to 3 and run the 88-98 3 in bore wheels caps is way better Posted via Mobile Device
///Relaxed Atmosphere |
or just some special hub cabs for for the center like on the Nacho truck right?
yes sir , drill and tap the wheels to use early clips and use what ever cap u want , i like the 55-56 chevy truck cap myself
