Old 03-21-2013, 05:13 PM   #1
77ChevySharkBite
77ChevySharkBite's Avatar
4 bolt or 2 Bolt
I found this on craigslist here locally, I'm thinking about maybe trying to get it but I wanted to know the ways to tell a 4 bolt main to a 4 bolt main here's the link to it. I want to check the vin to check but I dont know how.
http://houston.craigslist.org/pts/3606605113.html
thanks for the help guys
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 03-21-2013, 05:25 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 4 bolt or 2 Bolt
500hp go for four bolt. Under that the two bolt is fine.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-21-2013, 05:29 PM   #3
77ChevySharkBite
I wanted to do a 383 stroker for my truck, should I have a 4 bolt for that?
Korwin
Old 03-21-2013, 05:47 PM   #4
russgt
russgt's Avatar
You can tell from the pictures that it is a 4 bolt main block. I would have no issues pushing a studded main 2 bolt into the 400 to 500hp range, but for anything over that you should be using an aftermarket block anyways.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 03-21-2013, 05:52 PM   #5
77ChevySharkBite
Okay, see I didn't know how to tell the difference between them, or how to tell the difference I looked up the vin on it and it showed that it could be a 2 or 4 bolt and I figured someone here could help me out better.
Korwin
Old 03-21-2013, 06:16 PM   #6
tlawre87
tlawre87's Avatar
Look at the main bearing caps. (The three center pieces) It has 4 bolts. A 2 bolt main will only have 2 bolts.
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
Old 03-21-2013, 06:21 PM   #7
77ChevySharkBite
Okay I see it, so what would I need to pull off on my motor to find out if my current motor is a 2 or 4 bolt?
Korwin
Old 03-21-2013, 06:40 PM   #8
GM-power
GM-power's Avatar
Oil pan
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 03-21-2013, 06:45 PM   #9
77ChevySharkBite
And I'll just look for those same like 3 bolts or what?
Korwin
Old 03-21-2013, 06:49 PM   #10
GM-power
GM-power's Avatar
Look for four bolts on top of the main bearing caps tlawre87 said.
EDIT: I saw you other thread about pitting a cam in a 305. Is the motor you trying to figure out the the main bolt number a 305 or 350? Most 305 are two bolt. There are some rare 4 bolt 305s though according to some people.
Old 03-21-2013, 06:51 PM   #11
77ChevySharkBite
Alright thanks for all the replies guys!! I'm going to look into it pretty soon, can I do it with the motor still in the truck or do I need to have the motor out?
Korwin
Old 03-21-2013, 07:02 PM   #12
GM-power
GM-power's Avatar
It can be done without pulling the motor, but you may have to loft the motor up a bit and you might not have to. Not much help but thats just the way it goes sometimes haha.
Old 03-21-2013, 07:03 PM   #13
87r10owner
I have seen several 2 bolts pushed to 600hp and I'd take a splayed 2 bolt over a for bolt any day. I always thought that was a funny subject. But to the subject question yes it's a 4 bolt which for a street motor is irrelevant. But if you plan to do something with this where you get something extra is the fact that that block is a high nickel/high tin content. Just my .02
87r10owner is offline   Reply With Quote
Old 03-21-2013, 07:03 PM   #14
77ChevySharkBite
Haha I understand thanks for all the help and advice it's greatly greatly appreciated!
Korwin
Old 03-21-2013, 07:07 PM   #15
77ChevySharkBite
Okay but these 2 bolts are they splayed like you mentioned or are they actually just the 2 bolts? My truck is mainly going to be for show and to pull my boat, but if I can push good power out of a 2 bolt I'll just keep the 2 bolt in there
Korwin
Old 03-21-2013, 07:14 PM   #16
87r10owner
Just a 2bolt, and if you are not building a 500+ high rpm race motor than a 2 bolt will do any show or boat pulling you plan to do.
Old 03-21-2013, 07:18 PM   #17
77ChevySharkBite
Yeah, I'm just going to try and build a really good bottom end and have good torque and just let the HP follow it. If I want splay it, where can I get that done?
Korwin
Old 03-21-2013, 09:30 PM   #18
87r10owner
Just google splayed main caps and which ever one you decide on just take them with the motor to who have do the machine work and they can install them or you can purchase from any machine shop.
Old 03-21-2013, 09:44 PM   #19
77ChevySharkBite
Alright awesome!! Thanks for all the answers I appreciate it a lot
Korwin
