03-20-2013, 10:13 PM | #1 |
I have a gremlin
So side marker light wont light up. put a new bulb in it and nothing. tested to see if I was getting power, powers fine took a bulb out of one of the others and put it in the dead one and nothing. So I need some words of wisdom because I am stumped
03-20-2013, 10:30 PM | #2 | |
Re: I have a gremlin
Another thought, could be that the market light itself has issues. Maybe corrosion or something. Try installing the one from the other side to see if that works Posted via Mobile Device |
03-21-2013, 12:10 AM | #3 |
If you have power but it doesn't work, check your ground connection. My right front marker does that, and its a cruddy ground.
1971 C20 "Shreck" 1980 C30 dump bed "Ratchett" |
03-21-2013, 12:16 AM | #4 |
Ground would be the place to start if you have power and a know good bulb. What year is your truck and is it a front or rear?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-21-2013 at 12:17 AM. Reason: sticky n key |
03-21-2013, 12:25 AM | #5 |
yep ground! check continuity to body from light ground, easy fix
03-21-2013, 12:27 AM | #6 |
I agree man......check the ground wire from behind marker....if it looks ok there........try grounding it to the fender by hand just to double check it. you can always splice into a ground wire with no issues.
03-21-2013, 12:35 AM | #7 |
get a gremlin bell, problem solved
[that is a real thing ^ ] |
03-21-2013, 12:39 AM | #8 |
03-21-2013, 12:48 AM | #9 | |
had my left front turn signal go funky on my 86 bird, was to a point I just wired around it to make it work. ended up being one of the many marker lights in the tail goofing it up. making it act like a bad ground as it had power. |
03-21-2013, 07:04 AM | #10 |
gremlins are cool
03-21-2013, 07:16 AM | #11 |
as stated above check ground. My 68 did the same thing and it was the ground connection.
03-21-2013, 12:32 PM | #12 |
Mine did this on both marker lights on the passenger side. Turned out the socket was so loose the bulb wasn't making contact. Test light showed fine, but bulb wouldn't light. I spliced in 2 new sockets (they have them at any parts store) and it works fine now.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
03-21-2013, 11:35 PM | #13 |
its the pass side marker where is the grounding strap located. and yes gremlins are cool thats the only car I would trade my truck for.
