Setting Air Ride presets
I cannot get the presets to set when following the instructions. #1 will let the air out of all bags but I want #2 to automatically air to ride height with the ignition and when I follow the instructions I can't get it to save. Does anyone have any tips?
This is the control. Thanks. ![]() |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Setting Air Ride presets
Call or talk to Ridetech.
My E2 presets don't function properly in my blazer either. I just manually adjust my blazer. That's why my next bagged truck will have Accuair.
Thanks, I'll try Ridetech's forum or give them a call.
Man of Mini-Talents
I have an e3 set up and it works fine. I set it by manually setting each corner to the ride height I want, then press and hold the "2" button for a few seconds until the display indicates it's set. I doubt it's changed much from e2 to e3.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#5 | |
Does yours go to the #2 setting when the ignition is turned on? That's what I'm really hoping for. |
Man of Mini-Talents
I don't have mine set to do that but it is one of the settings in the setup menu. The compressor will come on at startup if necessary, but that's it for me. I'd rather control what it does myself.
Man of Mini-Talents
What did you find out?
