2WD Jimmy
![]() Join Date: Mar 2005
Single wall top glass
In pretty sure there is a thickness difference between the single and double wall glass. Does anyone know if you can use double wall glass for a pattern? My single wall did not have glass in it when I got it. I saved the glass out of my old double wall and was wondering if I could use it for a pattern to have the glass cut for my single wall (using the right thickness of course).
.......????? Posted via Mobile Device |
Collector of Projects
Re: Single wall top glass
I thought the glass was the same and the difference was in the seal that holds it in place...
My single wall top has the glass I pulled from an old double wall top. glass fit perfectly but the seals do not fit snug against the top. In some/ most spots there is about a 1/8" space between the outer seal and the top.
