Old 03-22-2013, 12:07 AM   #1
JonCheun
Battery Voltage Issue
I have a 68 C10 with a 1-wire configuration.
A few weeks ago I was driving to work and noticed my lights were dim and the voltage gauge read 11 Volts.
I first think the battery so instead of testing it, I just went ahead and replaced it with a new one.
Still the voltage was dropping. So I replaced the 1-wire 160 Amp Alternator with a new one from motor city reman.
I still had the receipt and it's 9 years old, I thought that was good so I bought a new one.
My issue is the volt gauge still reads 11 Volts when I am at a complete stop. I know the alternator is good b/c when I hit the throttle it goes to 13-14 volts but when I slow down and come to a stop it drops to 11 volts.
Tomorrow (Friday) I am going to go take back the battery and get another one b/c I don't think it is holding the charge.
I got the battery from Pep Boys so ProStart brand b/c it died in a parking lot and there was a pep boys in the lot.
It's a marine/rv battery.
JonCheun is offline   Reply With Quote
Old 03-22-2013, 10:24 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Battery Voltage Issue
If Pep Boys is like other auto parts stores they will want to charge and test your battery to make sure it is bad.
It depends on what marine/rv battery you have, if it is of the deep cyle type and not the starting type it will not hold up as well.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-22-2013, 11:47 AM   #3
cdowns
cdowns's Avatar
i would start by disconnectin wires and cleanin thenm and where they mount to nice shiny metal// especially gronding points so the electric flow
Old 03-22-2013, 04:30 PM   #4
JonCheun
I went to pep boys and decided to change the pro start battery to the optima battery.
I use a marine deep cycle battery (blue top) optima b/c i use the extra terminals for the 1-wire alternator, stereo, and extra stuff.
Does it matter if I use a Blue top in a truck?
Old 03-22-2013, 05:00 PM   #5
BMERDOC
BMERDOC's Avatar
What is your idle speed? Like cdowns said clean the connections. Not just the battery terminals but the other ends too, especially the ground at the block. If everything else is known good a low voltage at idle is usually from corrosion at connections or an excessively low idle speed.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-22-2013, 05:10 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Your idea of using a marine deep cycle battery is just as wrong as using a one-wire alternator for the loads you have in mind for your truck.
Get an optima red top and if you must have a one wire, then wire the output wire to a point that is a common junction for most of the loads in your truck.
The problem you are having is that you are reading the voltage drops on your wiring down stream from the battery, and the alternator is just charging the battery, (which is not designed to be used for repeated starts in short intervals like an automobile needs), and not compensating for these voltage drops by increasing it's output like a three wire alternator would.
If you are reading less than 12.3 volts on your battery with the engine idling, then the battery is not fully charged or it's bad. When the alternator drops to 11 volts the fields need more current to generate more output. A three wire alternator does this but the one-wire has to spin faster.
Cleaning all the connections is a good idea but I don't think it will make a difference. It might make the lights brighter but it won't help the alternator output.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-23-2013, 09:20 AM   #7
aussiec20
i had similar problem and it turned out to be pulley size was to big and didn't charge on idle, so i put in a smaller diameter pulley and fixed the problem.
1967 Chevrolet C20 fleetside vortec350/th400/Eaton HO52 NOSPIN 5.13
aussiec20 is offline   Reply With Quote
Old 03-23-2013, 10:21 AM   #8
68gmsee
Active Member
68gmsee's Avatar
As mentioned above check wiring and grounding points first. That's the easiest thing to do. Check and/or add ground strap from back of engine to cab, install addtional ground straps to any component that is isolated by bolts or rubber mounts like the cab or bed to the frame and even the radiator support. Bolts rust and reduce path to battery ground.
Also as mentioned above, get rid of the one wire and spend the effort to go with the proper alternator. They're cheaper and not that difficult to convert. One wire are easy to install but not the best for trucks or cars used in everyday driving situations. I have one on my farm tractor but it operates at high rpms almost all the time.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-23-2013, 02:03 PM   #9
BMERDOC
BMERDOC's Avatar
VetteVet has this stuff down pat. My experience is with stock style charging systems. After reading his post I decided to look up the cons of a one wire set up seeing as I have no experience with them.
http://www.madelectrical.com/electri...hreewire.shtml
Nick Carter
Old 03-23-2013, 06:57 PM   #10
JonCheun
Okay I got rid of the marine battery and did some rewiring so now I use the yellow top optima battery.
I will look into converting away from the 1 wire.
I bought this pick up a year ago and just been keeping it up and running so I just have been replacing parts with what was existing. Now that I have the time and some money. I will start to redo this truck the right way.
Thank You everyone for your help and for your help in the future. I have lots of little projects so let it begin.
Old 03-23-2013, 07:12 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by JonCheun View Post
...I bought this pick up a year ago and just been keeping it up and running so I just have been replacing parts with what was existing. Now that I have the time and some money. I will start to redo this truck the right way.
That's the way most of us have been doing our trucks -save some money and fix them up as we go. Also don't forget to let us know what the fix was. This will help others.
06 Trailblazer
Old 03-23-2013, 08:50 PM   #12
Andy4639
Old member
Andy4639's Avatar
Wink Re: Battery Voltage Issue
U can clean all u want, but if the system is only putting out 11 volts then your going to kill that new battery. The system is 12 volts min. and if your not seeing it then it's not going to help cleaning anything. Vett knows his stuff he has helped me more than once.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-23-2013, 08:53 PM   #13
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Alt should put out 14 volts or so.If the battery is below 12 and charged it's gonna be toast soon.If the alt isn't putting 14 into the batt something else is wrong.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-23-2013, 10:52 PM   #14
VetteVet
Msgt USAF Ret
VetteVet's Avatar
If you take your 160 amp alternator to any reputable shop they can change the voltage regulator to a three wire type and save you some $$$$$.Be sure to ask them if you have the SI style alternator or the CS style.Being a 160 amp I'd say it is the CS style.
In any case when your are ready to wire it in, come back and post in the electrical section and we'll get you fixed up. VV
VetteVet
