Dodge Seats in my 68?
Hey all, I was wondering if I could put Dodge bucket seats in my 1968 Chevy C20? Would new brackets need to be made or patching of previous holes? The reason I am asking is because I am looking at getting a pair of 2008 R/T seats for my truck and mounting them in there. I saw an episode of Overhaulin' where they put Hummer H3 seats in a 1972 Chevy C-20 but they had to make new brackets. If so, let me know because I think these seats would be awesome in my truck. Thanks!
Re: Dodge Seats in my 68?
Just a Heads up here is a picture of the seats...
Tot Roddin'
I moved your post to the 67-72 MB so you could get a few more responses.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
I am a Referee of life.
I put Mitsubish (Ithink) seats in my panel.I did drill one hole.The rest of the install was some 1- 1 1/2 square tubing and some 1 1/2 angle.I designed the mounts to use the original holes(Passenger on Panels only had one rear mount,thus the hole I drilled).I mocked everything up(the seats sat too low)then started measuring and adjusting.The front mounts to the angle and the angle to the original mount holes(with Fender washers),the rear mounts to the square tube and the original holes,plus the one I drilled.I used these seats because my drivers was junk and they were cheap at a swap meet.I gave $50 a for the 6 way power seats.The only way to see is to mock everything up and see what you need to raise level etc.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
the boat guy
I have a 98 ram seat in my 67. I made a simple perimeter frame out of square tubing then used the original rear mount and mounting holes. And some angle in the front.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
