Old 03-24-2013, 01:13 PM   #1
backtowork
what size and make rims/tires?
ran across this truck pic..wondering what kind(stock? aftermarket?) and size rims and tires and bolt pattern?.....will these also work on a 1998 GMC(5 lug)?...any trouble with backspacing?..any other mods that might be needed..I take it this truck has a cross member swap or 5 lug conversion..I like this look and am curious if these would be available in the local boneyards..
backtowork is offline   Reply With Quote
Old 03-24-2013, 01:33 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: what size and make rims/tires?
Those are dodge 20" steel wheels. (spares)
They are the wrong bolt pattern.
(5x5.5)
Your truck has a 5x5 pattern.
Keith
Convert to disc brakes.
Old 03-24-2013, 01:39 PM   #3
backtowork
Thanks..might there be a steel rally type rim bigger than the stock 15"(16,17,18) that would work?
Old 03-24-2013, 01:48 PM   #4
tonythezeek
tonythezeek's Avatar
i used this database to find wheels from other vehicle that might fit out trucks (provided you know the bolt pattern you are looking for)
http://www.roadkillcustoms.com/hot-r...e-Database.asp
updated link. should work now
tonythezeek is offline   Reply With Quote
Old 03-24-2013, 01:57 PM   #5
lolife99
lolife99's Avatar
Look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=546383
Keith
Old 03-24-2013, 03:05 PM   #6
dantimdad
dantimdad's Avatar
I thought those were off a newer Toyota fj cruiser.
They have the correct bolt pattern if they are.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 03-24-2013, 03:11 PM   #7
lolife99
lolife99's Avatar
Steven
Toyota FJ (spare) wheels are 17" and 6-lug.
Keith
Old 03-24-2013, 05:51 PM   #8
dantimdad
dantimdad's Avatar
Oh yeah, now I see. Sorry.
I want those!
Steven
Old 03-24-2013, 07:42 PM   #9
backtowork
thanks for the chart and info..will look for the 17" Toyotas to fit my '64 w/6 lugs..so I could use the 20" Chrysler rims w/ wheel adaptors...
