Old 03-24-2013, 05:56 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
120+ mph speedometer?
Does anybody make them for the 81-87's? 85mph just doesn't cut it! Or can somebody recommend a shop that can recalibrate and rescreen the gauge front?
Thank you!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 03-24-2013, 09:22 PM   #2
Skunksmash
Skunksmash's Avatar
Re: 120+ mph speedometer?
Autometer. Recessed into the gauge cluster. Would look pretty nice. However, I would like to know about a shop that rescreens gauges.
Skunksmash is offline   Reply With Quote
Old 03-24-2013, 09:26 PM   #3
MalibuSSwagon
I got a quote from Bobs Speedometer Service for $400 to Re-print the face to 120 MPH, recalibrate the speedometer for the new face, and set the mileage on the odometer. This was a rough estimate from them, they do free estimates if you ship the speedometer to them. Their work looks pretty good. http://www.bobsspeedometer.com/1/120/custom_work.asp
Another, less costly option, is to use a metric Canadian (Export) speedometer with a ratio adapter box. This box speeds up the cable so the kilos scale (0-140) will read as MPH.
MalibuSSwagon is offline   Reply With Quote
Old 03-24-2013, 09:49 PM   #4
69GMC910
MOTORHEAD!
69GMC910's Avatar
Yeah I have a KPH speedo right now and thought that might be an option! Thank you!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 03-24-2013, 10:36 PM   #5
MalibuSSwagon
Ahh I just noticed you are in Canada. That makes the project easier since you'll just have to source the ratio box. It'll work for MPH but will no longer read KPH, its up to you if that'll bother you or not.
