03-24-2013, 06:40 PM | #1 |
Active Member
Will truck start w/out gauge cluster plugged in???
Probably stupid ??? But will my 72 start without the gauge cluster plugged in???? I'm trying to fix a wiring problem between my junction box on the passenger fender and the fuse box. Also replacing some fuse links. I have my dash torn apart but just want to see if I fixed my start problem with my wires. I don't know if the gauge cluster completes and circuits in regards to starting...
67 C20 283/4 Speed |
03-24-2013, 06:44 PM | #2 |
Old member
Re: Will truck start w/out gauge cluster plugged in???
I don't know if it will start are not, it may start without it but make sure you have the oil line plugged off are you will pump oil out into the floor. Don't ask me how I know this.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-24-2013, 06:48 PM | #3 |
Active Member
Haha thanks. Good thing you said that because I would have forgot like someone else may or may not have done to theirs..
03-24-2013, 06:56 PM | #4 |
Old member
Avery long time ago in a very far away place there was a guy.....Lol!
03-24-2013, 07:31 PM | #5 |
It should start. Mine did.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
03-25-2013, 01:59 AM | #6 |
03-25-2013, 02:01 AM | #7 |
I have been wondering the same.
03-25-2013, 09:51 AM | #8 | |
I think many of us have done it.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
03-25-2013, 10:25 AM | #9 |
I drove my 69 15 miles without the gauge panel plugged in, it also had no windshield, door glass, rear window, grill, bumpers, etc. it ran just fine! I also drove my 72 in and out of my shop without the same. Yours should run fine without the gauges
http://smg.photobucket.com/albums/v655/aaronhero/ |
03-25-2013, 12:55 PM | #10 |
Mine started up just fine. I capped off the oil line right before I started it. Phew!
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
03-25-2013, 01:14 PM | #11 |
I've never tried with the oil line open but I used to work with a guy that said,
"You'd be surprised how much oil can come out of that line in a short amount of time."
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
03-25-2013, 01:30 PM | #12 | |
Old member
The grey carpet is long gone now but you can see the oil stain.
03-25-2013, 04:09 PM | #13 |
Definitely find a secure way to plug the oil line and you can drive all day long without the cluster. Dont recommend it since if anything goes wrong at all with the oil pump, or timing/distributor, or battery.......you wont know until its done its damage or left you stranded on the side of the road.
I drove my home right after installing my new Vortec (which has all electronic sending units now) and put in my new Dakota Digital Dash. |
03-25-2013, 04:54 PM | #14 |
just a couple months ago I ran into the same thing, my truck started with no problems without the gauges hooked up but I forgot to plug the line for the oil gauge and well of course oil on the carpet, luckily I have black carpet
