Old 03-25-2013, 11:55 PM   #1
msg
Tach install kit--also a filter?
I have read through the tach conversion threads which have been really helpful but the tach I was looking to buy at Classic Parts mentions the tach filter is a must. Anyone buy this kit and used the filter?
http://www.classicparts.com/1963-66-.../#.UVEZ0lvEr3k
Wasn't sure how difficult it might be, seems simple enough but thought I'd ask.
msg is offline   Reply With Quote
Old 03-26-2013, 09:00 AM   #2
duallyjams
duallyjams's Avatar
Re: Tach install kit--also a filter?
They recommend using the filter if you have converted to electronic ignition. I have one on the wife's truck.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-26-2013, 09:26 AM   #3
msg
I do have a converted HEI so I was going to buy it, were the filter install instructions pretty clear?
Old 08-06-2014, 04:16 PM   #4
csfields
csfields's Avatar
I got one from classic parts. How do you hook it up. Obviously the ground is simple enough, but not sure on the other two wires.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 08-08-2014, 07:37 PM   #5
msg
I havent gotten to the tach yet, hopefully someone will reply..or if you figure it out can you post a reply?
Old 08-08-2014, 10:00 PM   #6
DPowers
One foot in front of the other
DPowers's Avatar
http://www.classicparts.com/1947-72-...tinfo/24-736/#
Click on "Additional Images"
DPowers is offline   Reply With Quote
Old 08-08-2014, 10:32 PM   #7
csfields
csfields's Avatar
Hooked it up as suggested and everything works fine. When you get to it and have any trouble, message me.
Thanks,
Casey
