03-21-2013, 02:22 PM | #1 |
Camshaft for 305
I want to put a small cam in my 305 its stock except for headers and exhaust. I believe it's a flat tappet motor. I don't want to have a radical cam just a decent one to have a semi-noticeable lope.
All help is appreciated thanks guys!!
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
03-21-2013, 03:51 PM | #2 |
Re: Camshaft for 305
how fresh is the bottom end, and what is it going to be used for (street, strip)
is a realistic starting point. Cam change isn't a huge job, but it sure can be the start to one once you get started. Most of the cam companies have a tech guy to answer questions on their products,and what works best with your set up. good luck with your project. A cam lobe separation of 110 deg. vs. 112 deg. will make for a more radical sounding cam, but can come with less available vacuum for brakes, etc. |
03-21-2013, 03:56 PM | #3 |
thanks! it's a "rebuilt" 305 I'm lead to believe the PO just redid all the gaskets not a full rebuild on it, and it's going to be more of a street truck with 1 or 2 times on the strip just for kicks and grins.
03-21-2013, 04:49 PM | #4 |
78K & 79C Jimmys
I helped a guy put a 350 cam in a 267, he thought was a 350, so i'm guessin it could work for you too
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-21-2013, 05:29 PM | #5 |
hm....that's interesting!
03-21-2013, 08:03 PM | #6 |
Im dropping in lt1 cam in my 305, but im also going with a tpi setup too so trying to put in a cam that fits in the tpi rpm range.
03-21-2013, 08:17 PM | #7 |
Yeah I'm keeping my carb but I did some research and found a few that would work in it, thanks for the reply
03-21-2013, 08:39 PM | #8 |
Dude, you want a stock cam JK
If you want to spice it up I put a Summit 1103 in my truck. It's got a nice lope but it doesn't kick in till 2k. I don't know how it would act on a 305. You might want to check out the Summit 1102 (or cams with similar specs). Its one step down from mine. It will probably kick in a little lower as well. Again, I don't know how it would act in a 305 but the 1102 is supposed to be a good cam to spice up a stock 350.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
03-21-2013, 08:44 PM | #9 |
Yeah buddy! Send it my way!! Haha
Yeah I'm going to try and find a temp cam until I'm able to get some new heads and get a big and nasty cam! Posted via Mobile Device
03-21-2013, 10:41 PM | #10 |
Yeah I'd check into the 1102. It's like 50$ at summit which aint bad. Just throw in a set of lifters. Did a little googling around and that seems to also be the consensus from other sites.
03-21-2013, 10:43 PM | #11 |
Sweet!!! Definitely going to have to look into, thanks bro!! Your the bomb if nobody else has told you!
03-21-2013, 11:21 PM | #12 |
I've done a nasty cam on a 305. Afte 350hp these motors struggle at an increasing rate so you really have to fight them
Call the comp cams cam hotline. They will size a cam perfect for you and future mods. If you don't think the cam is quite big enough add higher lift rockers and that makes the cam seem bigger to the motor. Tell them that may be an option your doing As cam size has to be followed with the right size springs to follow it. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
03-26-2013, 09:28 AM | #13 |
Okay, so I wanted to ask a question. I've been doing some reading as for right now I'm not too worried on the performance end but if I do gain some HP that'd be awesome too. I'm thinking of putting a thumpr cam in my 305, will it fit with stock internals, of course I know I would have to change the lifters?
here's the link for the specs. http://www.compcams.com/Company/CC/c...?csid=107&sb=0
