Old 01-04-2013, 01:02 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Transmission crossmember
Does anybody know of an aftermarket crossmember for a 80's era truck that will allow for 3" dual exhaust? Also, will a 63-72 crossmember, like the ones performance online makes, still fit?
Thx!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi/3.42
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Ryan Brown Performance 850 Holley
Full weight long box pickup
Current best- 11.28@119mph
69GMC910 is offline   Reply With Quote
Old 01-04-2013, 03:49 PM   #2
FlatBlack83
FlatBlack83's Avatar
Re: Transmission crossmember
This is the one I used, Its technically for 62-72 trucks but the frame is the same width for 73-87 trucks.
I then fabbed up a custom 3 inch to run above the mount.
Built... Not Bought.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=536997
FlatBlack83 is offline   Reply With Quote
Old 01-04-2013, 03:52 PM   #3
FlatBlack83
I just re read your first post and the cross-member I used is the one from performance online!
My Build Thread
Old 01-04-2013, 04:35 PM   #4
69GMC910
MOTORHEAD!
69GMC910's Avatar
K awesome!!! Just RE ordered it!!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi/3.42
Mark Williams Axles
Cal-Tracs
Old 03-26-2013, 08:53 AM   #5
BugzC10
BugzC10's Avatar
FlatBlack....Where did you buy you tranny crossmember? Did it bolt into the same location as the old one?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-26-2013, 11:17 AM   #6
SCOTI
SCOTI's Avatar
I used the same trans x-member for my 89 TBI/454 dually (just had to slightly modify it). Dual 3" exhaust fit w/no issues. My fuel filter/fuel line routing & location kind of made life difficult & wouldn't allow me to run the pipes symmetrically but other than that they fit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-26-2013, 11:57 AM   #7
silvereagle07
silvereagle07's Avatar
That one is nice. Porterbuilt also sells one. He's a vendor here. It's the same one that comes in the dropmember kit.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-26-2013, 12:51 PM   #8
SCOTI
SCOTI's Avatar
I have 3 of PB's trans x-members. I like the way the POL/ECE x-members tie the top & bottom of the frame rail together similar to OE vs PB's or other similar aftermarket units that just bolt to the side of the frame. So the PB units are leaning against a corner in the shop despite the fact they are an easier install.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-26-2013, 10:25 PM   #9
FlatBlack83
I bought it from performance online, it lined up nicely with two of the already existing holes on the frame but i did have to cut/drill my other holes.
My Build Thread
Old 03-26-2013, 11:39 PM   #10
bdiamond
Want to sell one?
bdiamond is offline   Reply With Quote
