Growling noise from steering pump
I recently put power steering in the truck, holy crap what a difference!
However, if I start the truck when it's cold outside, the pump makes a growling/grinding noise. It stops making noise once the engine has warmed up and doesn't make any noise at all if it's warm outside when I start the truck. It's been on for about a month, so I don't think it needs any further bleeding. It's not low on fluid. It was a junkyard pump from a '76 and the gear is from an '81 so I switched the high pressure outlet to accomodate the metric thread gear line. What do y'all think? Get a rebuilt one? Is there something I can trouble shoot?
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
Re: Growling noise from steering pump
you sure the fluid is still full? I had this happen when replacing a pump. Once I had did the steering wheel type bleeding, it had sucked down enough to run it low. Unless there could be some metal in the pump gear housing.
I'll check again when I get home. I checked after I did the initial bleeding and it was full. At least that would be an easy fix. It seems weird how it stops when it warms up. Would the fluid expand that much?
![]() ![]() Join Date: Jan 2011
Could have a crawfish stuck in it or something ..
It is the season, and I do like them HOT!!
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Junior Member
I will bet it is low on fluid.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
is the belt tight enough?
This is my idea too. When the engine is cold everythings a little harder to turn making the belt slip. Plus the alt is charging harder after sitting all night and making the belt slip if not good and tight.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
