Old 03-26-2013, 02:11 PM   #1426
Rusbuilt
Rusbuilt's Avatar
Re: Project Grande Slam: Coley's Hot Rod Shop
Bumper looks much better! lol Will you be cutting off the excess threads from your u-bolts or will you just leave them that long?
Rusbuilt is offline   Reply With Quote
Old 03-26-2013, 02:12 PM   #1427
shawno72
C/10 junkie
shawno72's Avatar
Looking better and better Chad, keep up the good work
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-26-2013, 02:18 PM   #1428
CC69Rat
CC69Rat's Avatar
Yeah, I left the length on them just because if it's not low enough once I get the bed back on it, I'll add more block. If I add more block, I need more Ubolt so I just left that for the last thing I do. Those things are THICK man.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-26-2013, 02:21 PM   #1429
Rusbuilt
Rusbuilt's Avatar
lol good plan!
Old 03-26-2013, 03:13 PM   #1430
shawno72
C/10 junkie
shawno72's Avatar
Chad you are gonna need more block. I can see your frame isn't touching the ground yet
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-26-2013, 03:47 PM   #1431
nlped
nlped's Avatar
Chad,
Doe's the PB upper shock crossmember have to used with lower shock mount, or can it be used with the stock lower mounts? I ask because I really want to use the tubular crossmembers front to rear (minus the dropmember & trailing arm ones).
Oh, and I have a '70 front grille that you could have to practice on straightening. It's currently on mine, but I'm going to the '68 grille & hood. And I still owe you one for the shock relocation pieces.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 03-26-2013, 04:05 PM   #1432
CC69Rat
CC69Rat's Avatar
Originally Posted by nlped View Post
Chad,
The upper shock mount pulls the shocks around in front of the rear axle tube a little more, instead of the stock location pictured. It is designed to give you more of an Up/Down position than the angle you get when you lower your truck without relocation brackets.
The thing that concerns me about running the upper bar without the lower bar is the orientation of the shock bolt up top in relation to the bolt in the bottom. The angle would be quite a bit different. I'd be interested to see where the ECE brackets would put it compared to stock but I still dont thing it would pull it around (thinking efficiency) to the point the lower PB shock bar would put you. Honestly, .. I'd run both the upper and lower shock bars, regardless of stock trailing arms or Nate's. Just my .02
NOT just because I have PB stuff on mine, I understand there are trucks on here that are 10x mine or more .. I'm just saying, I would recommend Nates products to anyone. You can just 'see' the efficiency and geometry / creativity the guy has in his mind. Absolutely incredible stuff. Ed, my vote .. upper and lower PB. Pass on the relocators to someone else brother. Just me. later ..
(red = PB shock position, blue = PB lower shock bar)
Chad
Old 03-26-2013, 05:46 PM   #1433
67cheby
67cheby
67cheby's Avatar
man your detail work on the frame looks great !
67cheby is offline   Reply With Quote
Old 03-26-2013, 06:05 PM   #1434
original-71
///Relaxed Atmosphere
original-71's Avatar
i agree
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 03-26-2013, 06:10 PM   #1435
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Can't wait to see that thing on all fours....
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-26-2013, 07:02 PM   #1436
superflysteiny
superflysteiny's Avatar
Chad there is a guy in socal that delmo uses that can fix and polish that grill and make it look new again
superflysteiny is offline   Reply With Quote
Old 03-28-2013, 02:34 PM   #1437
CC69Rat
CC69Rat's Avatar
The front wheels have been ordered! Woohoo! Thanks again Eric for all your help.
Chad
Old 03-28-2013, 04:25 PM   #1438
nlped
nlped's Avatar
Sweet!!!
Carter
Old 03-28-2013, 11:35 PM   #1439
Bennett68C10
Bennett68C10's Avatar
Awesome
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-29-2013, 08:49 AM   #1440
Rusbuilt
Rusbuilt's Avatar
Yes! I hope they make it before the 13th and you and pops can drive it up here for the work day!!
Old 03-29-2013, 12:03 PM   #1441
knomadd
knomadd's Avatar
Can't wait to see the wheels on the truck! It's looking good so far, great job Chad!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-29-2013, 04:27 PM   #1442
NoNeck
NoNeck's Avatar
I'm going to come up to Nashville with Chad, but the only thing that worries me is the word "work". At my age, I mostly supervise!
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 03-29-2013, 04:34 PM   #1443
CC69Rat
CC69Rat's Avatar
Id say my wheels will be 4-5 weeks out.. maybe late April / May.
Chad
Old 03-29-2013, 11:18 PM   #1444
Rusbuilt
Rusbuilt's Avatar
Ha! I've got a nice seat where you can chill and point out everything we need to do!
That stinks! I guess I'll have to wait for HRPT to see it then!
Old 04-01-2013, 05:29 PM   #1445
shearjs
shearjs's Avatar
Chad, the truck looks awesome!
shearjs is offline   Reply With Quote
Old 04-01-2013, 05:38 PM   #1446
superflysteiny
Love the truck it is really coming out great. Did you get the wheels ordered?
Old 04-01-2013, 05:39 PM   #1447
superflysteiny
woops sorry just read your post great glad to hear you got them ordered
Old 04-02-2013, 08:55 AM   #1448
CC69Rat
CC69Rat's Avatar
Thanks Mike! Do those bed wood strips look familiar?
Originally Posted by original-71 View Post
i agree
Thanks Hector
Me either buddy, it should turn out to be a bit 'different' but that's what I wanted.
Honestly I probably wont keep it that long, just something for the new owner to do.
Thank you brother, it's been a long time coming. Ever since Eric posted those wheels in the For Sale section, I wanted them I just didn't have the $. I just decided to take the plunge and go 2-at-a-time. It has taken a while to save up and get them but I hope it sets this truck apart from the crowd.
Thank you! You coming to Rus's place on the 13th ?
Yep, you were actually in the shop when I was talking to APT. How long does it typically take to get wheels from Billet Specialties? I'm thinking 4-5 weeks?
Chad
Old 04-02-2013, 10:52 AM   #1449
CC69Rat
CC69Rat's Avatar
I read back through my own build on this truck and it's odd to me how it all panned out. Almost a year ago I said (I should have my wheels by Mid-May) .. and I still don't have them. They should be on it, well .. Mid-May.
No regrets though. My plans kinda changed yes, but I'm glad I went ahead and did what I really wanted. I can enjoy it for a month or so then just let er go. It will be for sale on the HRPT, and for whatever reason it doesn't sell I'll put it on eBay.
Dad and I are going to run the brake lines on Sat, and hopefully knock the inner bedsides down and prime. They're really pretty straight so it shouldn't take long to get them painted. (famous last words?) .. but then it's just finishing up the bed assembly and interior. I need to put the door panels on and detail around the lower parts of the doors where boots have just kicked the door open over the years and stuff. I need to get some nice black arm rests for it, a carpeted cover for the tank and maybe some new door handles and misc on the inside and it's done.
Then it's just waiting on wheels..
Once this one goes, my stepper is going to become a fleetside and layed out. Stay tuned to that one.
Chad
Old 04-02-2013, 12:04 PM   #1450
67cheby
67cheby
67cheby's Avatar
oh we will stay tuned ...don't worry ! LOL
