Old 03-27-2013, 10:57 AM   #1
ghill901
1970 C-10 knocking sound
I changed the carb on my 70 c10 with a Eddlebrock performance series 4 barrel. Char was running fine then i noticed a knocking sound as i accelerate. Any ideas?
ghill901 is offline   Reply With Quote
Old 03-27-2013, 11:33 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 1970 C-10 knocking sound
Carb may be lean and now it's pinging? just first thought to pop into my head and that hurts this early LOL
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-27-2013, 11:40 AM   #3
~Whitey~
~Whitey~'s Avatar
sounds like the timing is off... probably advanced too far causing pre-detonation.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 03-27-2013, 11:51 AM   #4
ghill901
the timing is what i thought was off also, I had the timing adjusted but still the same rapid knocking noise. Also when i decellerate my truck backfires. it sounds like it is coming from the carb itself. What controls the spedometer cause when i hit 60mph the needle goes crazy and drops.
Old 03-27-2013, 12:09 PM   #5
truckster
truckster's Avatar
I would look for a lean mixture as well.
The speedometer is run by a cable coming from your transmission. If it works correctly up to 60, it's likely the speedometer head (the part behind the dial you see on your dash) needs to be repaired.
truckster is online now   Reply With Quote
Old 03-27-2013, 06:58 PM   #6
ole dollor
ole dollor's Avatar
i would pull all the plugs out and see if they have been hit by anything ...a bolt or nut could have been in the intake or fell in while you had the intake off, right now it could be holding a valve open, also run a compression check and see whats going on...i sure hope i am wrong..but it want take a lot of time to do this , before more damage could be done..
ole dollor is offline   Reply With Quote
