Closed Thread
Old 03-27-2013, 07:02 PM   #6451
mud.man.rj
mud.man.rj's Avatar
Re: What did you do to your truck today!
Well started on my 454 last night and tore it all down. Today did some cleanup on heads, port matched intake gaskets to 781 oval port heads and did some mild porting, also started on port matching Edelbrock RPM intake and mild porting also, here are a few pic's will post more as I go. Mudman.
Well back to work, more cleaning then start painting block and parts.
mud.man.rj is offline
Old 03-27-2013, 10:25 PM   #6452
HotRod C/10
HotRod C/10's Avatar
installed Porterbuilt panhard bar.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline
Old 03-27-2013, 11:12 PM   #6453
RustedMetal
RustedMetal's Avatar
Vintage 70's pabst blue ribbon tap shifter installed
RustedMetal is offline
Old 03-28-2013, 05:03 AM   #6454
CSGAS
optomistic ah-so
CSGAS's Avatar
Originally Posted by BigDaddyV View Post
....Then Caught the carb on fire.......
I lost a '72 Big Block Charger that way when I was too young to know how to deal with it...or is that young enough to know everything? I keep getting those two mixed up!
The next time I had a carb catch on fire--real fire not just a little backfire--was when overheated tranny fluid puked out the filler tube on a Cordoba. Must have been ignited by one electrical wire or another. That wouldn't have been any big loss. I knew how to starve it of air though and had lots of good parts perfectly usable for another project.
Well, the day's just beginning...I may fall asleep in my truck somewhere or I may put some of the parts I've had lying around here for months, on it, or even go to the junkyard for more valuables that I can either sell or keep.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline
Old 03-29-2013, 07:35 PM   #6455
Mayo
Cool Truck
Mayo's Avatar
Finished up recovering my door panels and then installed them. I started this project about year ago and it was a bit of a pain putting them back in, but its finally done.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline
Old 03-29-2013, 07:50 PM   #6456
VWNate1
VWNate1's Avatar
Thumbs down Re: What did you do to your truck today!
I damn near cried ~
Yesterday I drove to get a haircut and the building owner ran the corner stop sign and banged the back bumper & fender in.....
Lucky for me I had my ipod thing-A-ma-jig as I'd been taking pix of my new Grand Daughter , I snapped pix of him , his truck , my truck etc. ~ he gave me a copy of his license and says he'll pay , we'll see .
I'm bummed out .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 03-29-2013, 08:01 PM   #6457
mud.man.rj
mud.man.rj's Avatar
Wow that sucks, is there a lot of damage, will prob get ahold of you with pic's and all.
Old 03-29-2013, 08:20 PM   #6458
shawno72
C/10 junkie
shawno72's Avatar
Those blocks look fabulous
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 03-29-2013, 08:37 PM   #6459
67Slider
67Slider's Avatar
Made the 100 mile trip to the body shop with the suburban packed with finishing parts. Checked out the progress on the 67. Guys were color sanding the front fender. One of the body shop guys dropped my newly upholstered door panel and ripped the fabric about two inches. Looking good but still a long way to go. Looking at June or so before it's done.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 03-29-2013, 09:26 PM   #6460
Mr Handy
Mr Handy's Avatar
beat on the lower area of the bedside... looked like someone ran over a big log and dented the heck out of them on both sides... the panhard bar also has about a 20* bend in it... I have an adjustable one coming from ece. Anyway the bedsides look a lot better now, could still use some finessing before new paint, but definitely look better.
Over the weekend I got my HEI distributor and new wires installed... all the plugs looked awesome when I pulled them out, cleaned them, gaped them and put them back in... engine sounds great now... also got one of the motor mounts replaced... the bad one. still need to replace the other... but I plan to pull the motor and swap the heads... trying to decide if I want to put in a different cam, lifters, springs when I do. I have some minor leaks so will be replacing gaskets anyway.
Mr Handy is offline
Old 03-29-2013, 09:54 PM   #6461
Bloodyjaws88
Today I pulled the cowl panel and moved the rightfront fender away from the door after the PO put the truck in a ditch. The same PO also put the replacement bed on crooked, so the wife and I straightened that out. Then we put the rear bumper back on. Next is adjusting the trans and pulling a few leafs to lower the rear.
Chris
Bloodyjaws88 is offline
Old 03-29-2013, 11:00 PM   #6462
Square_78
Square_78's Avatar
Got all the holes drilled and got my EXO mount for the Accuair bolted to the frame. Ran all the power wire and mounted the solenoid inside the frame rail. Ran the USB cable into the cab for the controller and also the ignition feed wire up into the dash. Tomorrow I just need to connect a couple ground wires and solder on one copper ring terminal onto the 4 awg power wire at the solenoid and then I can power the system up. I would have finished it today, but I ran out of gas for my soldering torch and couldnt connect the power cable securely. No bags installed yet, but hopefully I can get started on that next week sometime.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline
Old 03-29-2013, 11:30 PM   #6463
HotRod C/10
I cleaned em up on the edge sander at work........
LS SWAPPED
-1976 SILVERADO
Old 03-29-2013, 11:31 PM   #6464
HotRod C/10
fired up the 383 today after having it built 3 years ago!
LS SWAPPED
-1976 SILVERADO
Old 03-29-2013, 11:32 PM   #6465
Expat_dude
Expat_dude's Avatar
Test fitting new grill
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Old 03-30-2013, 01:02 AM   #6466
buckskins4ever
buckskins4ever's Avatar
I ordered a adjustable pan hard bar. Needed for the lowering setup. If you email me your address, I will ship you my old one if you want an OEM...Its straight.
buckskins4ever is offline
Old 03-30-2013, 02:31 AM   #6467
Scott>72-GMC
Scott>72-GMC's Avatar
Originally Posted by Ol Blue K20 View Post
Sometimes us geezers are the problem just ask my neighborsthey frown on open headers, the skeet tourneys my kids,their friends and I have and the two am stereo contests but the closest is a 1/4 mile away. I tell em come over enjoy and get over themselves
These old people are the ( want ur yard looking like a baseball outfield perfection no cracks in your driveway no cars in the driveway professionally landscaped yard) kind of neighbors. Not that I like my yard a mess or looking crappy. But if I got a project and want to use my driveway I will
72 GMC super custom.
Scott>72-GMC is offline
Old 03-30-2013, 08:55 AM   #6468
Mr Handy
Mr Handy's Avatar
Thanks, I appreciate it, but I ordered an adjustable. I plan to lower at some point so I figured I would kill 2 with 1.
The PO put 5 lug shafts in but left the 6 lug in the front. I plan to put the 6 lug shafts back in shortly (I have them! and the rims) and then measure for blocks to get her level. then down the road I plan to do drop spindles and disks in the front and springs in the back. At the end of the day it will be a 2.5/4 or 5 drop...
Sense this is a what did you do thread, I also degreased my engine compartment, painter my air cleaner with some paint I had sitting around and Power washed as much of the frame I could get to without getting wet while laying on the ground... seems to have made a difference....
Mr Handy is offline
Old 03-30-2013, 09:20 AM   #6469
ryanroo
ryanroo's Avatar
I am definitely "that guy" in the classy as small town colorado can get neighborhood here. in the warm snowless months, my wifes jeep is outside, my F250 DD the yellow 72 K20 is a driveway monument, my M715 lives next to the house and my trailer is in front of the 715. everything is parked on legit parking surface, and i keep the yard well kept. but no one every has a problem finding my house.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline
Old 03-30-2013, 02:24 PM   #6470
GoaterAz
GoaterAz's Avatar
I made a paint booth! haha...out of a box and some toothpicks.
before
after
GoaterAz is offline
Old 03-30-2013, 03:54 PM   #6471
c10srule
c10srule's Avatar
replaced the 2" exhaust with 2.5" and replaced the edelbrock 600 with a holley 750 vacuum secondary, the performance is like night and day
c10srule is offline
Old 03-30-2013, 09:36 PM   #6472
OregonNed
OregonNed's Avatar
I had it power tuned last week so I took it out today - first day this year over 70 degrees and sunny. Drove it like hell! It sounded and ran so nice!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 03-30-2013, 09:43 PM   #6473
BOHICA-Chevy68
put on power brakes
finished the 200-4r conversion.
hooked up the TV cable to my single barrel carb
put on linkage
changed out the steering column to a automatic
put on my 20 in rims
new fluids; oil, transmission, diff
welded new shock mounts on the frame
BOHICA-Chevy68 is offline
Old 03-30-2013, 11:18 PM   #6474
Square_78
Square_78's Avatar
Finished wiring all my Accuair and fired it up for testing.. Works like a dream. All ready to mount the bags and connect the air lines. C-notching the frame and doing the rear bags on Wednesday.
#teamlongbed
Old 03-30-2013, 11:22 PM   #6475
heathbirkendahl
Got her ready for motor swap.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline
Closed Thread
