Old 03-27-2013, 12:45 AM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
harness question PLZ help
I am almost done depinning/ reorganizing my harness...a 1999 silverado 4.8l and I am trying to figure out what these 4 wires need to do...
first off my dad said they came from the fuse/relay panel two wires are a heavy gauge green, 1 is purple/white, and the last is yellow... all 4 of these wires go into the section of the harness for the transmission... both of the greens, the purple/white, and the yellow all go into the 6 pin transmission plug that was glues in from the factory... i will provide a pic here asap...
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 03-27-2013, 01:03 AM   #2
1970 C10 MJW
Re: harness question PLZ help
this is the connector i speak of.... please help me guys
Old 03-27-2013, 03:28 PM   #3
ls1nova71
ls1nova71's Avatar
The purple and white wire comes from the crank fuse, or the start side of your ignition switch. The yellow is the wire that goes to the starter relay. The green wires are B-shift interlock, and F- back up lights.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-27-2013, 03:37 PM   #4
1970 C10 MJW
Are these needed?
Old 03-27-2013, 11:34 PM   #5
ls1nova71
ls1nova71's Avatar
Technically, you don't NEED them, but it's nice to have them hooked up. If your column has a neutral safety switch, you can use it. The transmission mounted ones are just a little more accurate, since any slop in the shift linkage doesn't affect it.
Old 03-28-2013, 10:46 AM   #6
1970 C10 MJW
ok well i guess i could use them.. how would i wire yellow to the starter relay? and what do the greens wire to? and what does the purple wire do?
Old 03-29-2013, 08:47 AM   #7
mrhurt73
i had to draw it out before it made real sense to me
see attached picture the left side of the photo shows internal wiring diagram
right side shows descriptions that make sense.
hope this helps
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 03-29-2013, 11:10 AM   #8
1970 C10 MJW
thanks MR HURT
