![]() ![]() Join Date: Jan 2002
wind shield crome
what is the best way to get the crome out of the windshield
gasket. thanks gary |
remove the windshield take the gasket off the glass and the chrome comes right out , you cant remove the chrome with the glass installed
![]() Join Date: Aug 2001
![]() IF YOU WANT TO SAVE THE GASKET, THE BEST WAY IS WITH THE WINDSHEILD OUT OF THE TRUCK. IF YOU DON'T CARE ABOUT THE GASKET & PLAN ON REPLACING IT ANYWAY, CUT AWAY WITH AN EXACTO-KNIFE OR RAZOR-KNIFE. JOHN ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
thanks I will take the windshield out first what is the best way to take the windshield out.
"Ochre Ogre"
The fun way is with a hammer. Second best is to cut the gasket from the inside of the cab. I like to use a hook blade. I have tried to take a windshield out but have never done it without cracking it. Thats why I like the knife. The gasket is old in most cases anyway.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
![]() ![]() I'M WITH DA-BURB.. IT SEEMS LIKE I'VE BROKEN MORE WINDSHEILDS TAKING THEM OUT, THAN PUTTING THEM IN. ![]()
![]() Join Date: Nov 2001
When I did my 70, I just busted it out, it had to be replaced anyway. Now when it came time to reinstall and having the experience from my 69, I called safelite. Get this... they charged $17.00 for installation!!!!! I could not belive it! I supplied the gasket, they supplied the windshield. As soon as the service man arrived, he called into the shop and had another guy come out to help. Well they fought for about an hour and decided that the window was not made right and would not fit. They left and retuned in about an hour with a brand new LOFF! It fit perfect and they did not charge me the extra 160 bucks the LOFF cost!
Well as soon as they left I took the hose to it, sure enough it leaked. I called thier shop and with in ten minutes the guys were back. Pulled it out and reinstalled it. Well since then it still leaks but it has a lifetime leak warrenty so someday I am going to take it to their shop and have them fix it but I ma in no hurry, I would not drive it in the rain and have only put 150 miles on it since 1997! Rick H...
Rick H.... 69 C10-CST Wood bed floor full power 70 SWB 425hp HOTROD! Full power 71 C20 Camper Special 402 full power, factory dual tanks with gauge switch. FOR SALE! |
Blazerless:-(
I took my blazer to safelite also- Beautiful job- great price and lifetime leak warranty!
Diane |
If I am planning on saving the glass and rubber seal , I spray it inside and out with WD-40 or equivalent , and take my plastic winshield knife and work the rubber from the inside . I start on a outside corner cause you kinda have to keep pressure on it , right in the middle will usually crack the glass . If it has been in there a long time , it may be tuff . Thats my pennies worth .... jyd
thanks junkyarddog
I have one that is allready cracked so I will try that one first thanks Gary |
