Old 04-05-2012, 01:40 AM   #1
cfan10
cfan10's Avatar
Cool Please, help me with removing pass. exhaust manifold
Can someone please tell me what I am doing wrong, pass side exhaust manifold is cracked. I've undone the bolts from the block, but the top has this square like bolts that will not budge with adjust wrench, also cannot get bolts loose that connect to the exhaust pipes using long 9/16 socket.
Is there a way to get this done without an impact gun? Thanks so much for advice.
Also, pass exhaust pipe is twisted under bed of truck now, I know because muffler is crooked.
85 swb
305 v8
Dual exhaust
cfan10 is offline   Reply With Quote
Old 04-05-2012, 07:38 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Please, help me with removing pass. exhaust manifold
i"ll be doin this later,got my mufflers in
if rusted solid and not being reused,snap off the 9/16 up to the manifolds
I will hit the manifold bolt straight on before turning,trying to shock/loosen it a bit
when you put new nuts on the exhaust consider brass nuts!
they don't rust
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-05-2012, 01:30 PM   #3
76Charlie
76Charlie's Avatar
Try using PB blaster, make sure it doesn't get into the engine or anything bad like that, or use WD40. then put the wrench on it, and hit it with a rubber mallet
1976 GMC SIERRA CLASSIC CAMPER SPECIAL! 454 BIG BLOCK BABY!
76Charlie is offline   Reply With Quote
Old 04-06-2012, 01:15 AM   #4
cfan10
cfan10's Avatar
What am I missing here, I tried still nothing. Square bolts that goes into head, not engine block. Anymore advice is appreciated. Thanks.
Old 04-06-2012, 01:24 AM   #5
76Charlie
76Charlie's Avatar
Torch? wait for someone else to chime in before you try that though! don't wanna mess anything up
Old 04-06-2012, 06:01 AM   #6
Phillip Pennartz
Those square like bolts might be pipe plugs used when the air injector tubes are removed.
Might just cut exhaust since its twisted, easier than getting some really stuck bolts that hold the pipe on.
Phillip Pennartz is offline   Reply With Quote
Old 04-06-2012, 08:59 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
it's not the "other" temp sending spot? coolant?
does the manifold look like this?
John
Old 04-06-2012, 09:31 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
or
John
Old 04-06-2012, 03:01 PM   #9
cfan10
cfan10's Avatar
Cool Re: Please, help me with removing pass. exhaust manifold
Originally Posted by motornut View Post
or
That is the location on the square bolt, unlike the pic it has no connections to it. And it is 2 bolts, 1 is thru the first hole on engine, the other is at the back of engine by motor oil dipstick.
My dumb (smartphone) will not let me upload pics to photobucket, or vids to youtube. I will keep trying. Thanks.
Old 04-06-2012, 06:33 PM   #10
88Jimmy4x4
88Jimmy4x4's Avatar
if thats them, then you shouldnt have to remove them as they dont screw into the block
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-07-2012, 08:26 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
x2
John
Old 04-07-2012, 12:53 PM   #12
cfan10
cfan10's Avatar
Its the same location at the top of exhaust manifold, but is not the same thing. The bolt on mine goes from that location into the exhaust manifold hole on engine block. Not to be confused with the six bolts on the exhaust manifold.
These square bolts are the only thing holding the exhaust manifold up, as the six bolts have been removed without trouble.
I am thinking this is why it stayed cracked so long, its a pain in the ass to deal with. May end up putting it back. Thanks.
Old 04-07-2012, 12:55 PM   #13
cfan10
cfan10's Avatar
Old 04-07-2012, 12:57 PM   #14
cfan10
cfan10's Avatar
Sorry for the double post. Even tried vise pilers, smaller socket.
Old 04-07-2012, 01:07 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
Suggest posting a picture
John
Old 04-07-2012, 02:05 PM   #16
cfan10
cfan10's Avatar
Can't because my phone will not upload.
Old 04-09-2012, 07:00 AM   #17
88Jimmy4x4
88Jimmy4x4's Avatar
here it is
1991 GMC Jimmy 4x4
Old 04-09-2012, 07:20 AM   #18
jjzepplin
jjzepplin's Avatar
That looks like an old plugged air-injection tube. With the flange bolts loose from the exhaust that should just come out. I don't think that is a bolt or has any function at all. You could just cut it off but you risk it falling into the cylinder. If you do cut it off turn the engine over til the exhaust valve is closed. If you take the motor mount bolts loose and lift the engine you may get enough room to pull it straight out. Since your manifold is of no use to you don't worry about hurting it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-09-2012, 10:40 AM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
wedge it from moving...vise grips
couple of nicks/cuts into both sides,
with a grinder/ cutting wheel,
hammer it ,
bet it would crack off
heck hitting it with a small sledge alone, might crack that
John
Old 04-09-2012, 01:05 PM   #20
cfan10
cfan10's Avatar
Originally Posted by 88Jimmy4x4 View Post
here it is
Thanks so much, I really appreciate it!
Old 03-29-2013, 01:12 PM   #21
IHeartGroceries
Sorry for the thread revival, but I am in a pickle.
I have a 72 C-10, 350/350, and one of the nuts on the driver side exhaust mani (manifold to exhaust flange) backed out and fell off. The stud is good. I need dimensions of the nut size. The hex is 9/16", but what thread type?
IHeartGroceries is offline   Reply With Quote
Old 03-29-2013, 02:12 PM   #22
LynnJr
If its all original everything on the exhaust is 3/8-16 threads
LynnJr is offline   Reply With Quote
