Old 03-29-2013, 02:19 PM   #1
LynnJr
Unbending Brake Lines Smoothly?
I just got my Inline Tube brake lines in the mail and the two long lines were bent in half so they would fit in the box.The bend is a half circle about 6 inches across and I don't want to kink it unbending it and I would prefer it to come out smoothly.
Any ideas on getting it unbent and still looking halfway decent?
Should I just cut out this section and a small length of tubing?
If I knew this was what I was getting I would never have bought it.
LynnJr is offline   Reply With Quote
Old 03-29-2013, 02:22 PM   #2
Low87
been here longer than Liz
Low87's Avatar
Re: Unbending Brake Lines Smoothly?
I'd call the company and ask how they propose you unFUBAR the lines they sent.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-29-2013, 02:53 PM   #3
LynnJr
This is the reply to my e-mail
Shipping bends are required to ship all lines over 6 feet in length. This bend is a large-radius bend that is the same as a 5 gallon bucket. The tubing is not stressed so the bend is easily straightened to the original form. To remove the shipping bend, simply unroll the section marked between the tags on a flat surface such as a table or garage floor. Use the floor as a straight edge. Whatever gentle bend is left, straighten by hand. When the tube is straight you are done.
Not much help as my bends are 6 inches and not a 5 gallon bucket in size.
I will call them.
Old 03-29-2013, 03:24 PM   #4
LynnJr
Called
The guy on the phone said use my garage floor as a straight edge and if it doesn't work send them back.
Looks like I'm headed to the brake shop to have some parts made.
Old 03-29-2013, 03:39 PM   #5
Low87
Low87's Avatar
5 gal bucket radius I can see, 6" not so much. Easy to mess that up. Good luck.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 03-29-2013, 03:43 PM   #6
shawno72
C/10 junkie
shawno72's Avatar
Funny I just got my brake lines from POL and they are bent as well. Mine look to be quite easy to bend back straight.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-29-2013, 04:49 PM   #7
silvereagle07
silvereagle07's Avatar
You should be able to do what the guy on the phone said. I've have them shipped to work all the time like that. Just get a helper to hold the lines flat on the floor and slowly roll it out. There are some hand forming pliers that could help. If rolling them out doesn't work send them back for a refund. I would rather have a line kit for the truck rather than have a shop install lines and unions They have a potential to leak.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-29-2013, 06:17 PM   #8
LynnJr
Problem solved.
The guys at the front end shop bent them straight and showed them to me.I then had them cut the newly formed wiggly sections out and they built me two replacement lines and re-flared my old lines(one day old) so the length was right.Took him 15 minutes tops.
Silvereagle07
This was there best kit and there was no way to lay it flat as it was full of bends and curves.
I asked the guys at the front end shop if this was normal and they said nobody ever sees there brake lines and this was typical of the lines they see.
My original old brake lines were better shaped and have no wiggly sections in them.Live and learn I guess.
Old 03-30-2013, 07:37 AM   #9
silvereagle07
Cool. Glad you got it resolved.
Jeramy
'85 Chevy 4X4 SOLD
