Old 03-29-2013, 04:31 PM   #1
frog210
okay well i dont have brakes
I was getting ready to head to work, so I warm up the truck, get in it, pressed on the brake and that thing went down easy... I pumped it like 3-4 times and it for hard, so I moved it up the driveway, like 40ft and press on the brake it did the same thing had to keep pumping it to stop it,
I think it has a JB1 brake system, manual brakes, disk front drum rear, checked the rear wheels and drums to check for leakage, but found nothing... The original master cylinder is leaking around the top
So I'm going to go to autozone and order a new master cylinder, I guess my question would be how do I go on and replace the master cylindser, I think I have to bench bleed the new one correct, any tips for a rookie?
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 03-29-2013, 04:44 PM   #2
G8DAN
G8DAN's Avatar
Re: okay well i dont have brakes
yeah you will have to bench bleed the new one. I just did this recently and it is a pretty simple task. Just make sure you dont strip the nuts on hard lines.
G8DAN is offline   Reply With Quote
Old 03-29-2013, 04:49 PM   #3
frog210
Any special tools needed to bench bleed the master?
To take it off master cylinder just remove the 2 bolts in the engine bay correct? Or is their something holding it on in the cab?
San Antonio, TEXAS
-Frog
Old 03-29-2013, 06:53 PM   #4
Jonboy
Slots go on anything!
that's pretty much it. If you don't have a vise to bench bleed the master on, bolt it on the truck, and then bleed it before you put the lines on.
Jonboy is offline   Reply With Quote
Old 03-29-2013, 07:47 PM   #5
frog210
Cool I guess when I get home, I will start spraying some liquid wrench or wd40 on the bolts so it won't give me so much trouble tomorrow lol thanks guys
San Antonio, TEXAS
-Frog
