Old 03-29-2013, 05:05 PM   #1
oldno7
oldno7's Avatar
dash removal
http://67-72chevytrucks.com/vboard/a...1&d=1364590984 Any tips on how to get this dash out without breaking. I'm not familiar with the 60-66 years. I'm thinking the ingition needs to come out
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 03-29-2013, 05:15 PM   #2
tincan1966
tincan1966's Avatar
Re: dash removal
All the switches need to come out before you can remove the cluster assembly.
tincan1966 is offline   Reply With Quote
Old 03-29-2013, 05:29 PM   #3
jesseo
jesseo's Avatar
Re: dash removal
That tach has to come out and shipped to me in Oregon. Where I can take very good care of it.
jesseo is offline   Reply With Quote
Old 03-29-2013, 07:39 PM   #4
oldno7
oldno7's Avatar
Re: dash removal
So i have the ignition out, and the wiper knob is off. On the lights i have the knob off ,but on the back side where you press the spring loaded switch the black box is what i need to figure out.
oldno7
Old 03-29-2013, 11:12 PM   #5
CRGRS 66
CRGRS 66's Avatar
Re: dash removal
you have to remove all of the switches, etc., the headlight knob has to come out, but the headlight switch must also come out. Ignition switch, wiper switch (not just the knob), headlight switch, lighter, what else, um, choke... it all has to come out.
Let us know how you make out.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 03-30-2013, 08:51 AM   #6
1963c-10
1963c-10's Avatar
Re: dash removal
dont forget to disconnect speedometer cable and oil pressure line. the headlight switch is easy, the bezel will thread out from the front dropping the switch out the back. then disconnect the harness. the black cover stays attached to the switch
1964 Short bed trailer
