Closed Thread
Old 03-25-2013, 07:55 PM   #7251
dantimdad
dantimdad's Avatar
Re: What did you do to your truck today?
Sorry, Don, here is a pic:
Daniel is chomping at the bit to paint the scripts black.
Thanks again!
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 03-25-2013, 10:25 PM   #7252
steve'62
steve'62's Avatar
steve'62 is offline
Old 03-25-2013, 10:29 PM   #7253
steve'62
steve'62's Avatar
Started on the cpp disc brake and drop spindle! The old spindle removal was a huge PITA.
steve'62 is offline
Old 03-25-2013, 10:34 PM   #7254
Ta2Don
Ta2Don's Avatar
Thanks again!
Steven
Looking Good! The black script will look sweet!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline
Old 03-25-2013, 10:34 PM   #7255
steve'62
steve'62's Avatar
steve'62 is offline
Old 03-25-2013, 10:42 PM   #7256
steve'62
steve'62's Avatar
steve'62 is offline
Old 03-25-2013, 10:43 PM   #7257
steve'62
steve'62's Avatar
steve'62 is offline
Old 03-27-2013, 09:09 PM   #7258
T Smith
T Smith's Avatar
Worked on it a bit this afternoon, it's sittin but not drivin...
T Smith is offline
Old 03-28-2013, 10:15 AM   #7259
steve'62
steve'62's Avatar
steve'62 is offline
Old 03-28-2013, 03:46 PM   #7260
Touchdown67
Touchdown67's Avatar
Installed a IPod stereo set up today. It consists of a Kicker Pxi50.2 controller a Kicker HS8 powered subwoofer and a pair of 4" 2-way speakers mounted in a pair of moulded plastic Versa-pods. The sound is incredible and it is totally hidden from view.
Touchdown67 is offline
Old 03-28-2013, 04:59 PM   #7261
mud.man.rj
mud.man.rj's Avatar
Cam/dbl roller timing chain installed/used an XE270 Comp 4x4 Extreme cam. Heads are ported and lifters/pushrods and roller rockers installed, going back out to finish porting intake now, can't wait to hear it run.
mud.man.rj is offline
Old 03-28-2013, 08:21 PM   #7262
donthekawguy
donthekawguy's Avatar
Put on my new visors, wipers and cleaned up the heater box and put in a new core. Now I have heat just in time for summer.
66 shorty
donthekawguy is offline
Old 03-28-2013, 08:45 PM   #7263
mud.man.rj
mud.man.rj's Avatar
Ported and port matched gaskets on Rpm intake, ready to install, getting closer.
Old 03-28-2013, 09:36 PM   #7264
Trsmotrhed
Trsmotrhed's Avatar
Installed autometer phantom gauges. Get paid Monday and will order the electronic speedometer and tach.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 03-28-2013, 10:30 PM   #7265
azdude1964
azdude1964's Avatar
*****in
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline
Old 03-28-2013, 10:33 PM   #7266
azdude1964
azdude1964's Avatar
ran a 6 ga. wire to my efi to stablize the volts. then took it for a cruz to see if it helped..and it did,,
Old 03-29-2013, 05:02 PM   #7267
azdude1964
azdude1964's Avatar
enabled the autotuner on my megasquirt to tune the truck wow this things gonna be scary fast
Old 03-29-2013, 05:41 PM   #7268
1964Chevy
1964Chevy's Avatar
To say that I did this today would be a lie. It has taken me about a month. Removed the original rad and installed new aluminum, lost the old broken shroud and noisy fan and installed an electric fan. Also removed the leaking LMC master cylinder and put new mc and reconditioned booster.
Hope everyone has a relaxing Easter Weekend.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline
Old 03-29-2013, 06:34 PM   #7269
donthekawguy
Started blasting my new to me rear end. I didn't have a lot of time so I just messed around for a bit. I am using a HF 50 lb blaster. I just wish I had a bigger compressor. It will take a couple of hours to get it done but it will look good. I'm going to put new seals in it por 15 it and put on a chrome cover and olts. The brakes will be all new and new u joints. I'm also having the trailing arms powdercoated and new bushings and bolts. 1st pic is half blasted pumpkin 2nd pic is the axle tube kinda blasted.
66 shorty
Old 03-29-2013, 07:28 PM   #7270
jayoldschool
Moderator
What are your compressor specs? I've got a single stage 60 gal, 135psi. I wonder if that's enough for occasional blasting...
jayoldschool is offline
Old 03-29-2013, 07:45 PM   #7271
donthekawguy
Mine is a 25 gal 125 psi. It will work but its going to take a while because I will have to stop and wait for it to refill.
66 shorty
Old 03-29-2013, 07:54 PM   #7272
gimmy 64
it is all about cfm's what does youre's put out at 90 lbs? mine puts out 8.5 at 90 and it still needs to catch up
gimmy 64 is offline
Old 03-29-2013, 08:10 PM   #7273
awbrown
Took ol' blue out for the second run of spring...kinda' thinkin' it is time for a front sway bar .....
awbrown is offline
Old 03-29-2013, 08:22 PM   #7274
donthekawguy
Mine is only 4.3 at 90. Its good for about 30 seconds at a time. Maybe time to go get a new compressor.
66 shorty
Old 03-29-2013, 09:56 PM   #7275
62 Barnfind
62 Barnfind's Avatar
Installed my carpet today!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Closed Thread
