Electrical help
So here's my problem the fuse box is not getting power but the alt and starter are , headlights only work when motor is running, turn singles and four ways work as well as break lights but no marker lights front or rear , gauges all work but no gauge panel lights except high beam indicator is this one problem or diff ones it's a 85 silverado k10 single cab long bed 350 sbc this it the last thing I need to figure out to get it inspected ne one have ne ideas that this could be
Posted via Mobile Device |
#2 | |
Re: Electrical help
Re: Electrical help
I did all of them are good I have to pull them bc there's no power to the fuse block I read on google someone hade the same problem and the only answer was to tighten the block on the fife wall witch u did and it's tight
Moderator
![]() Join Date: Oct 2008
Re: Electrical help
You likely have a burnt fusible link at the starter.
According to GM, in 1985, power feed to the fuse block is a 3mm˛ (@12awg) red wire circuit #2J. The red wire is protected by the smaller 1mm˛ (@18awg) fusible link at the starter. The 1985 GM wiring diagrams are in my signature.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#5 | |
![]() Join Date: Dec 2012
Re: Electrical help
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
Re: Electrical help
Ok thanks everyone lets hope that's it haha
Re: Electrical help
Doesn't a the fuse block get fed off the distribution block in the middle of the firewall?
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
Re: Electrical help
Re: Electrical help
Ok so I checked the block on the fire wall every thing is good I'm starting to think its that switch since everything works but the marker lights and the dash lights ne one have ne other ideas what it could be......
#10 | |
Moderator
Re: Electrical help
In 1985 GM used two fusible links at the starter. They're separate from the junction block.
Re: Electrical help
I checked them there getting power
Re: Electrical help
How did you check the fusible links?
Those test lights where you clip one end to ground and the other end is pointy is great. You can pierce insulation and see if the wire is hot AND the lamp gives enough of a load to prevent false readings. |
Parts and more parts
Re: Electrical help
Check the fuseable link that is by the firewall between the brake booster and the engine. I have a couple of these go out and now I carry a couple with me in that truck all of the time. I just went to the salvage yard and cut a couple out of the leftover wiring harnesses that were in the trucks.
Frank |
#14 | |
Re: Electrical help
#15 |
Re: Electrical help
I only had to do it once, but having the extra in the glovebox, is a comfort to know vice having someone haul you home on a flatbed. Especially if you are 3000 miles from home on a trip.
Frank |
| Bookmarks |
