Old 03-28-2013, 09:05 PM   #1
1963-4x4
1963-4x4's Avatar
Question About to replace the wood bed, have some questions!
So, I just finished tearing out all the old, rotted plywood from my 63, and I have a few questions regarding replacing it.
I can't afford a kit premade for replacing it, so I'm resorting to some DIY options. I plan on using 2x6's for my replacement wood, and without the metal strips that go between them. I was wondering how much should I plane off of the wood, what kind of gap should I leave between them, and if 2x6's are even the best option. For anyone who has done this before, how wide was the wood you used?
Pictures are always appreciated!
1963-4x4 is offline   Reply With Quote
Old 03-28-2013, 09:14 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: About to replace the wood bed, have some questions!
Use 1 x (3/4" thick) lumber. Anything else will throw off your bed height. Thicker wood wont fit into the front roll pan either. Check out GMC Pauls for directions on how to make your own replacement wood. http://www.gmcpauls.com/47-72_BedWood_Info.htm
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 03-29-2013, 10:24 AM   #3
62 Barnfind
62 Barnfind's Avatar
I also cut my bed myself using GMC paul's dimensions. It's not hard just use a scrap piece first to cut it right. It cost me about $80 to do it.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 03-29-2013, 11:01 AM   #4
1963c-10
1963c-10's Avatar
Be carefull if planning on using treated lumber....some of the new chemicals will rust / eat metal.
1964 Short bed trailer
Old 03-29-2013, 11:13 AM   #5
1963-4x4
1963-4x4's Avatar
Thanks a bunch, that website will definitely help me a lot!
Old 03-29-2013, 04:16 PM   #6
'65 chevy lover
Great site Sillyoldman! Thanks for posting that!
'65 chevy lover is offline   Reply With Quote
Old 03-29-2013, 05:37 PM   #7
jesseo
jesseo's Avatar
Getting ready to do the same myself. Got the wood today and plan to work on it the next couple of weekends.
jesseo is offline   Reply With Quote
Old 03-29-2013, 07:41 PM   #8
jayoldschool
Moderator
Is pressure treated ok to use if the wood is completely primed/painted with exterior paint?
jayoldschool is offline   Reply With Quote
Old 03-29-2013, 07:50 PM   #9
68panelman
68panelman's Avatar
Pressure treated lumber is no good as bedwood. The sun makes it crack,check,warp within 8-12 months, It's only good when in constant moisture/water. As a Dockbuilder by trade, ask me how i know.
68panelman is offline   Reply With Quote
Old 03-29-2013, 08:19 PM   #10
Rich 5150 69
Rich 5150 69's Avatar
Glad I got rid of the wood 20 years ago.....T6061 T-6 alum plate.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-29-2013, 08:45 PM   #11
jayoldschool
Moderator
My deck is made of pressure treated. It still looks fine ten years after being built. It sits outside all year in the rain and snow....
Old 03-29-2013, 09:13 PM   #12
bschoolz1
also used pressure treated wood in my bed no problems at all just a ***** to cut
bschoolz1 is offline   Reply With Quote
Old 03-29-2013, 09:53 PM   #13
jayoldschool
Moderator
Did you paint it?
Old 03-30-2013, 09:24 AM   #14
68panelman
68panelman's Avatar
Just giving an opinion, If i was replaceing bedwood, Thats a job i would want to do only once.
Old 03-30-2013, 12:08 PM   #15
jayoldschool
Moderator
I completely agree, I only want to do it once. What else would you suggest for a truck that is going to sit outside. I will paint it. Low cost is good, too!
Old 03-30-2013, 12:58 PM   #16
Clyde65
Clyde65's Avatar
I've seen some guys use that composite lumber before, that is maintenance free and will probably outlast the truck, only issue is the cost.
I called a lumber company and asked for Hicory/Pecan wood. Cut to my dimensions was $175. Picked up. Before you say anything, I gave them what GMCPaul had. It is a very hard wood,will weather well and take stain easily. This is what I'll do for my bed when I get to it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
