Old 03-30-2013, 11:28 AM   #751
shawno72
C/10 junkie
shawno72's Avatar
Re: Shawno72's long overdue 68 daily driver build thread
Ok guys I have run into a snag with the disc brake install. I installed the POL Disc brake conversion front hard line set and it fits pretty good. I got the CPP disc brake front conversion hoses from a board member and the hose ends are larger than the line ends my question can I go with a set of factory stye 71-72 front brake hoses?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-30-2013, 11:29 AM   #752
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by fastcam1 View Post
I'm with you about the metal shavings just had to drill a couple of rivots out the other day. As for the front alignment, could you just set your ride height then have them do the alignment for that specific height?
I had my alignment guy, (a gearhead, and good friend), align my blazer.
I told him to align it as low as possible.
He did the best he could at keeping it low,... but I would have liked a lower ride height.
That's really what a Dropmember is for.
LOW ride heights!
Keith
Convert to disc brakes.
Old 03-30-2013, 11:33 AM   #753
lolife99
lolife99's Avatar
If you can find "inverted flare" adapters,... you can use them to adapt your hoses.
The 71-72 hoses have two different size hose fittings.
(thats the way they were from the factory)
So you would still need an adapter on one side.
I used the ECE conversion hoses on my red '69.
They are a direct bolt on.
I have extra long 73-87 hoses on my blazer, so it doesn't stretch the brake line so tight when air'd out.
But they require an adapter also.
I got my inverted flare adapters at my local ACE hardware store.
Keith
Old 03-30-2013, 11:35 AM   #754
lolife99
lolife99's Avatar
You need the "tube" adapter.
http://www.oreillyauto.com/site/c/se...1164/C0248.oap
Keith
Old 03-30-2013, 11:38 AM   #755
shawno72
C/10 junkie
shawno72's Avatar
Thanks Keith I am checking into that now!!
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 11:40 AM   #756
lolife99
lolife99's Avatar
Originally Posted by CC69Rat View Post
Unibits are awesome when drilling frame holes.. that may be what you mean? (7/8 bit..) just saying, they are expensive but worth every dime. I have a titanium one thats awesome. One bit did all the holes for my rear PB stuff.
My bags are mounted directly to the frame.
Slam Specialties bags have a huge port size, (3/8"npt or 1/2"npt), that requires a pipe thread bushing to reduce down to my PTC air line fitting.
I think I used a uni-bit up to 3/4" and then cleaned up the hole with a 7/8" standard drill bit with a 1/2" reduced shank.
Keith
Old 03-30-2013, 12:06 PM   #757
HotRod C/10
HotRod C/10's Avatar
Call MIDAS, they should know.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-30-2013, 12:14 PM   #758
shawno72
C/10 junkie
shawno72's Avatar
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 01:39 PM   #759
shawno72
C/10 junkie
shawno72's Avatar
Ok so I bought a set of the 4x4 front brake hoses from Oreillys and they fit like a glove and are longer for the aired version thats coming Anyone else ever tried this?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 04:28 PM   #760
lolife99
lolife99's Avatar
Part numbers?
71-72 4x4 application?
Keith
Old 03-30-2013, 04:53 PM   #761
shawno72
C/10 junkie
shawno72's Avatar
Part numbers?
Oreilly's part number BH79339 and they are for 72 4x4. Had to cut the two ears off but they bolt up to the caliper just like the conversion hoses. Plus I didn't need and adapters
I still need to figure a sanitary way to mount them to the lower A arm. Any ideas?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 05:09 PM   #762
shawno72
C/10 junkie
shawno72's Avatar
Some more progress, check out how short the PO cut the stock coils. That's my 3" drop coils next to them.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 06:06 PM   #763
shawno72
C/10 junkie
shawno72's Avatar
Almost there......
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 06:10 PM   #764
lolife99
lolife99's Avatar
Must be nice to have a lift and your own alignment equipment available to you.
You're killing your mods one by one!
Keith
Old 03-30-2013, 07:13 PM   #765
Bennett68C10
Bennett68C10's Avatar
Drilling the frame sucks!
I was sick of metal shavings. Ha.
I ended up using a 7/8" drill bit for the air fitting hole.
I suggest using the hat's first and see how far you get into your c-notch,... especially since you have 2" lowering blocks.
Everyone talks about "low" ride heights.
And yes,... you can drive it as low as possible.
But you will have to air up quite a bit to get the front end back into alignment.
Just depends how often you want to replace your front tires.
Very well said. One reason why I used the hats was I didn't want to go through all the work of drilling the frame for the fittings and bolting the bag down. I also new at some point I would go much lower with the dropmember, just didn't realize it would be this soon When I had the bags mounted with the plates it bottomed out in my notch with the 2" lowering blocks. Now I had welded in my own notch but it was equivalent in height to cpp or porterbuilt. Also with the 2" blocks your ride height will be lower then if you didn't run the blocks with the plates. I also agree with Keith that low ride heights require a dropmember and is ultimately why I decided to just do it.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-30-2013, 07:33 PM   #766
shawno72
C/10 junkie
shawno72's Avatar
It is a real blessing plus I get paid to do it
Great now you got me thinking that everything I did today was a waste Now I gonna have to bag it and THEN decide its not low enough when I knew up front that the dm was what was needed.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 07:37 PM   #767
shawno72
C/10 junkie
shawno72's Avatar
And some pics of the finished product. The front ended up much lower than I really expected even though it was right on with Keiths red truck. It dropped an additional 1 1/2" I think the brakes may still have some air but we ran out of time so I'll have to bleed them some more. I forgot to tighten that little tiny plug on front of the prop valve Oh has a super nice stance and with 7" in wheels all around I am gonna just roll it for a bit......then maybe a drop member??
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 07:46 PM   #768
lolife99
lolife99's Avatar
Looks good.
The stance is perfect!
The 4x4 hoses have a through frame connection just like the 73-87 hoses.
I think there should be a nut on this hose to mount it solid to the bracket.
How close are your a-arms to the ground?
You might have to learn how to drive it differently.
Watch out for potholes in the road!
Keith
Old 03-30-2013, 07:50 PM   #769
shawno72
C/10 junkie
shawno72's Avatar
Looks good.
I used the standard c or u clip from the old hose and it is holding nice and secure but I will check the wrecking yard next time I'm out for that nut. I have def reached the lowest static point without changing the crossmember or doing a step notch in the bed. The A arms are low low low so I will watch where I go carefully. Luckily Lodi streets are very well maintained and very rarely have any issues that aren't dealt with in a day or so.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 08:00 PM   #770
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
looking good Shawn
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-30-2013, 08:19 PM   #771
CC69Rat
CC69Rat's Avatar
Looks great buddy! The stance is perfect.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-30-2013, 08:22 PM   #772
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
OUTSTANDING!! Oops, sorry, didn't mean to yell. Looks great Shawn!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-30-2013, 08:46 PM   #773
shawno72
C/10 junkie
shawno72's Avatar
Originally Posted by Ol Blue K20 View Post
looking good Shawn
Thanks Dale, you gonna make the Stockton swap meet and BBQ 2 weeks from tomorrow?
Thanks Chad, lets see how long I can leave the suspension alone
Thanks Buck!!!
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-30-2013, 08:50 PM   #774
VA72C10
VA72C10
VA72C10's Avatar
Nailed the stance!
Old 03-30-2013, 08:53 PM   #775
RRC
RRC's Avatar
Nice fix with the 4x4 brake line!!!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
