![]() Join Date: Dec 2012
Engine block numbers
I am certain the restored '68 I bought has the original 327 in it that was rebuilt in '07 - however, there are no numbers etched on the pad in front of the right cylinder head. Is that normal at all?
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
Cluster King
![]() Join Date: Nov 2012
Re: Engine block numbers
If the machine shop machined the deck surface, that would wipe the stamped code off. It will be on the passenger side front.
check driver side just below the head at the firewall block numbers will be there
That is probably it - passenger side front. Ill check in back by the firewall for the casting numbers. Thank you
