Speedometer
I bought my 79 Silverado and the Speedo didn't work. I checked the cable and it was broken. I replaced the cable and went on a freeway drive today. This is what I was picking up:
Kinda funny. But I couldn't have been going more than 85 mph. Anybody know how to calibrate a cable speedo? |
Re: Speedometer
The gears in the trans change your speedo info
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Parts and more parts
Re: Speedometer
This website has a lot of info on what you need for speedo gears and from that you should be able to calculate what you need to make your speedo run right.
http://www.transmissioncenter.net/sp...FS-oPAodO3wA_Q
Frank |
Moderator
![]() Join Date: Oct 2008
Re: Speedometer
Several years ago I put together a spreadsheet to calculate some "what ifs" for axle ratios and tire sizes. RPM_Gear_Axle_Transmission_TransferCase.zip
The sheet calculates ideal speedo gears based on tire size and axle ratio. Rows 50-100 are the speedometer info. Modify the blue numbers in rows 6-11 to match your axle ratio and tire sizes. The sheet also calculates RPMs at various MPH based on tire size, transmission ratios, and rear axle ratio. Change the red numbers in M8-M14 to match your transmission ratios.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
