Closed Thread
Old 03-31-2013, 02:23 PM   #1901
dubie
dubie's Avatar
Re: What Did You Do With Your Truck Today ?
Holy hell, that looks just like my wife 58 fleetside sitting in the yard, Now THAT'S a driver!! nice one man!!
I cut out the rust in the other step side fender last night and welded in new metal. I ran out of gas shielded wire after my first 2 tacks so I had to do the rest of it with flux core. After a couple burn through, I got the heat dialled in and got it done. The bed is now ready to be roughed up and shot with primer.
I took a stripping disc to the lower part of the front drivers side fender thinking there would be some rot hiding behind the apparent bondo abuse and yet, the metal was clean. This truck does however have a ton of brazing done to repair some older front end damage. I've come to the conclusion that I've been over thinking the body on this truck and need to stay on task with my original build plan and have a rough body on a modern chassis and powertrain set up.
I have this entire week off work so there will be some major progress happening on this thing. Wiring and mounting body panels are on the top of that list
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 03-31-2013, 03:31 PM   #1902
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by Daze57 View Post
...40 ft or 400 ft looks really nice
...and 389 miles is FLAWLESS! Lol.
Dan in Pasadena is offline
Old 03-31-2013, 07:28 PM   #1903
Rude Dude
Rude Dude's Avatar
I like the fancy Aluminum recovery tanks but can't see in spending that much money for something I can not see the fluid in. I needed an overflow tank for the radiator so went to Autozone and bought one of the generic plastic recovery tanks. I used the factory holes that where already drilled, put in Three rubber grommets for hose and two behind the mounting bracket so it wont rub against the the paint, also split a gas line and placed on the lower bracket in two spots that lay against the fender wheel all for under $10.
Rude Dude is offline
Old 03-31-2013, 08:07 PM   #1904
Dan in Pasadena
Excellent and cheap...which of course is the only better than excellent alone!
I never thought of not being able to see the coolan.! I HAVE a fancy spun aluminum one I've not installed yet and hadn't considered that.
Old 03-31-2013, 09:43 PM   #1905
tttuba
Stripped the bed of the wood.
tttuba is offline
Old 04-01-2013, 09:20 AM   #1906
dubie
dubie's Avatar
Originally Posted by sqrlnts View Post
From this
To this in 4 hours, brushed on enamel. Took almost as long to tape off the spears and the cab for the two tone as it did to paint the whole thing black. I will call it a 40 footer! I plan to let the paint cure then sand down through it.
So what color is under neath the black? or are you just sanding through to what you previously had
dubie is offline
Old 04-01-2013, 11:50 AM   #1907
hsdropout
Installed rear fenders, not as easy as it might seem...........
hsdropout is offline
Old 04-01-2013, 01:25 PM   #1908
Dan in Pasadena
Looks good. I can't remember if you used welt between the fender & bedside or not? Was the hassle just that they're big & awkward?
Old 04-01-2013, 01:55 PM   #1909
hsdropout
Dan, I like your chrome letters, I might have to go for some too. Yes, welting, really nice stuff I got from Classic Parts and yes...................just award, a lot of up and down, crawling under, reaching etc, some 30+ bolts if you include the spare tire bracket which was challenging in itself.......
I'm not a spring chicken. (58 years young, sound familiar?)
Old 04-01-2013, 02:45 PM   #1910
Midgets50
Midgets50's Avatar
Worked on my truck over spring break, found out starter needs to be rebuilt, cleaned gauge glass and got the front axle cut out and the other mocked up, pulled out the seat and nasty shag interior carpet it had along with gas tank which surprisingly is in great shape
Midgets50 is offline
Old 04-01-2013, 03:29 PM   #1911
sqrlnts
Dubie, I will just sand through to the original colors beneath the black.
sqrlnts is offline
Old 04-01-2013, 08:12 PM   #1912
agnes the dog
agnes the dog's Avatar
Drive 200 miles to get a new front end with genuine Nostalgia Sid 3" drop axle, new brakes, bearings, rod ends, steering box, shims, and assorted accessories! Got the whole ball of wax along with new leaf springs and a pair of wheels for $300!!!! Score!! Can't wait to get back home to put it all together.
agnes the dog is offline
Old 04-01-2013, 08:57 PM   #1913
broey
Square
broey's Avatar
didnt do anything to the truck today, but I did finally become a premium member on the forum.. does that count?
Squarebody Syndicate
broey is offline
Old 04-01-2013, 09:16 PM   #1914
lowdownstar
big guy
lowdownstar's Avatar
YES
Ray
lowdownstar is offline
Old 04-01-2013, 09:48 PM   #1915
mechanixman
mechanixman's Avatar
Pulled out the dash pieces.
Labeled them and put them away for a rainy day.
I figured each part would make for a nice small project. i.e. Gauges, heater, turn signal assembly
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline
Old 04-02-2013, 02:31 PM   #1916
1-ton of fun
polishing a turd
1-ton of fun's Avatar
removed the stock rear springs and front leaf spring mounts.
then mocked up the 4-link:
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline
Old 04-02-2013, 10:36 PM   #1917
mknittle
mknittle's Avatar
I did some measuring and more measuring. Now I have a pretty good idea where my engine and transmission is going to sit. It helped when I decided to go with a pusher fan in front of the radiator.
Now to mock it all up and make motor mounts.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 04-02-2013, 11:39 PM   #1918
mavdog32
front boxing plates tacked in and front crossmember swapped to a chevy instead of a GMC.
mavdog32 is offline
Old 04-03-2013, 03:04 AM   #1919
mechanixman
Is that mount part of a 4 link kit?
Or did you fab it yourself
-Nick
Projects:
Old 04-05-2013, 07:00 AM   #1920
dubie
dubie's Avatar
we mounted the cab, hung the doors, tried to fit the front clip but due to some older front end collision damage, it's going to take a little massaging to make it all work properly. We installed the Rebel wire fuse panel and ran all the wires to their future homes and also went through the chassis from front to back re-chcecking every nut, bolt, grease nipple, cotter pin, etc to make sure it's all there. It was a pretty productive few days off and I have 3 more to go. I'd like to think I could get the wiring damn near done before I go back to work
dubie is offline
Old 04-05-2013, 09:44 AM   #1921
Denee007
Denee007's Avatar
I installed my LED tail lights, hooked up the wiring and every thing works! I also put on my windshield wiper arms, but I had the under the dash arms on the wrong things making the wipers go the wrong way! I corrected that painstakingly and that's fine now, of course I checked the direction before putting the arms on~ that would have been disastrous!
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline
Old 04-05-2013, 09:50 AM   #1922
Denee007
Denee007's Avatar
Larry, you brushed (as with a brush?) on the enamel? and it came out that nice?
Denee007 is offline
Old 04-05-2013, 11:38 AM   #1923
Daze57
Daze57's Avatar
denee007
your truck is turning out very very nice
Daze57 is offline
Old 04-05-2013, 02:03 PM   #1924
sqrlnts
Denee, If your asking about my paint job, yes it was put on with a brush. And for the record its John not Larry!
sqrlnts is offline
Old 04-05-2013, 02:54 PM   #1925
Denee007
Denee007's Avatar
Oh, forgive me! Your truck looks so much like pbeguy(Larry)! I would have bet money it was his without looking at the username! Well, it's still incredible looking!; )
Denee007 is offline
Closed Thread
