Old 04-01-2013, 02:55 PM   #801
shawno72
C/10 junkie
shawno72's Avatar
Re: Shawno72's long overdue 68 daily driver build thread
Originally Posted by Ol Blue K20 View Post
Don't know but it does sound like fun
Check out the California section. Its a good way to meet many local forum memebers.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-01-2013, 03:11 PM   #802
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by shawno72 View Post
The new master is for manual not power brakes. Not sure but I don't think any Corvettes in 1975 came with drum brakes......I hope
Sorry Shawn, the corvette thing got past me but as long as the booster is working it sounds like line pressure problem. The corvette was usually 4 piston calipers on all four corners. Do ya know someone you can borrow a stock truck master w/ discs/drum combo to try out. I'm just wondering if the vette had different pressure requirements
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-01-2013, 03:15 PM   #803
shawno72
C/10 junkie
shawno72's Avatar
I was thinking that the Corvette master would be overkill if anything. Should squeeze those calipers with no problem. I'm thinking that maybe the booster is the issue. I noticed on the O'Reilly website that the corvette booster is a dual diaphragm.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-01-2013, 03:20 PM   #804
Ol Blue K20
good thought, did you change the booster as well. I see the new prop valve
Dale
Old 04-01-2013, 03:49 PM   #805
shawno72
C/10 junkie
shawno72's Avatar
No. I am using the same booster.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-01-2013, 03:57 PM   #806
Ol Blue K20
I would think the stock booster would work with the vette master but now I'm not sure. I'm sure the booster is still working or you would hear the vacuum under the dash when brakes are applied or run funny. Only I can think of is the master isn't making the pressure you need. You're getting good pressure when bleeding correct?
Dale
Old 04-01-2013, 04:23 PM   #807
jlsanborn
jlsanborn's Avatar
Truck is looking sharp man, nice work! So them spindles are a 2-1/2" drop, plus a 3" spring??? What size rubber on there?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 04-01-2013, 04:49 PM   #808
Ol Blue K20
Yeah Shawn, I've been peeking in there now and then (quietly)
Dale
Old 04-01-2013, 05:44 PM   #809
shawno72
C/10 junkie
shawno72's Avatar
Actually the pressure is ok but not super great. Not bad enough to cause concern.
Thank you!! Yes 2.5" spindles and 3" springs. Tires are P215/70R15 up front and P235/75R15 out back.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-01-2013, 06:19 PM   #810
Ol Blue K20
Well Shawn, I'm at a loss, the only thing I can think of is the master. Trucks run one large piston and vettes four small pistons. I would try a truck power master and see how that changes things.
Dale
Old 04-01-2013, 09:49 PM   #811
shawno72
C/10 junkie
shawno72's Avatar
The booster is working good so either I need a different master or a bigger booster........I think
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-01-2013, 11:39 PM   #812
jlsanborn
jlsanborn's Avatar
Thanks! If you get a chance, snap a picture of the ground clearance at the a-arms. I'm banking on a 4-1/2" advertised drop (2-1/2 + 2) and 235/60's working for me.
Old 04-01-2013, 11:45 PM   #813
shawno72
C/10 junkie
shawno72's Avatar
Your welcome. I'll snap a couple pics tomorrow.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-02-2013, 12:19 PM   #814
shawno72
C/10 junkie
shawno72's Avatar
Well it's not a very good pic but I hope it helps. I would say the LCA's are about 2.5" off the ground.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-02-2013, 01:12 PM   #815
shawno72
C/10 junkie
shawno72's Avatar
Look what I got today. Do you know what this means?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-02-2013, 02:20 PM   #816
fastcam1
Young gun
fastcam1's Avatar
Install tonight!
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 04-02-2013, 03:36 PM   #817
shawno72
C/10 junkie
shawno72's Avatar
Originally Posted by fastcam1 View Post
Install tonight!
Very soon, very soon.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-02-2013, 06:18 PM   #818
sduckworth13
sduckworth13's Avatar
Hey Shawn, your truck is looking great. Nice job on the suspension, how does it ride now? I did a similar setup and my 1967 GMC longbed truck, rode like it was on rails going around corners.
Scott
sduckworth13 is offline   Reply With Quote
Old 04-02-2013, 06:21 PM   #819
shawno72
C/10 junkie
shawno72's Avatar
Thanks Scott. The truck rides so much better with the correct lowering springs. Not quite on rails but much stiffer through the turns
I will probably install the rear air bags this weekend
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-02-2013, 06:36 PM   #820
sduckworth13
Lol, I guess any upgrade of suspension I would say was like riding on rails when I did my suspension. I had the death wooble going on, you know when you only was going change one lane and your truck decides it wants to change two and the only way to make it quit wobbling was to drive faster... Lol. Nice work, looks great.
Scott
Old 04-02-2013, 07:31 PM   #821
Daaaanz67
Phew that's low, I know Lodi has good roads what about some of those long trips that you'll be going on and what you might encounter. I'd like to go lower on mine but to worried. Roads in my area are pretty rough. Anyways looking good Shawn.
Daaaanz67 is offline   Reply With Quote
Old 04-02-2013, 07:52 PM   #822
shawno72
C/10 junkie
shawno72's Avatar
Thanks Dan, yeah up there where you are I can see some of the roads getting a bit rough. For me its the price I'm willing to pay to look
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-02-2013, 09:40 PM   #823
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
And it does look!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 04-02-2013, 10:30 PM   #824
jlsanborn
jlsanborn's Avatar
Attachment 1086175
Yikes! I'd theoretically be 1/2" or so higher but that's probably pretty nominal. It's going to be low and I sure can't say the same about our streets up here. Thanks for photo man!
Old 04-02-2013, 11:00 PM   #825
shawno72
C/10 junkie
shawno72's Avatar
Originally Posted by BucksSS View Post
And it does look!
Thanks Buck. I'm wondering how it would look with some 20s?
I'll take an exact measurement in the morning.
I got a little something done tonight. I'll post a pic in the morning
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
