high-Tech Red Neck
Custom Trailer Winch Mount
I picked up a new trailer on Friday.
![]() Nice trailer but still needs a few things, one of those is a winch mount. I have a Warn 12 series 12K industrial winch. I downloaded the plans, then designed this: ![]() It is a receiver mount and winch plate that will go on the front of the trailer, allowing me to remove the winch to use it on other things as well. I started cutting the pieces tonight, I need go buy a new drill bit and the piece of reciever tube I am using. The nice thing about the design is you can still stick a ball holder in it and tow a trailer with the winch in your hitch. I designed it this way in case I ever have to tow someone else'es trailer and need a winch and it does not have one. I doubt that will ever be the case however because my trailer is a 20' deck which means I can load a crew cab dually on it with no issue as long as I have enough truck to get the job done. This trailer is going to get quite the workout here soon, I have to make a run to Corpus the beginning of next month and get my 72, then I am probably going to wind up rolling over to Austin and buying a 3500HD over there I have been looking at building another welding rig out of. Hopefully in the next few days I can get everything knocked out, I also bought housings and all LED lights for the trailer, but those are not going on it until I have the room to park it inside, which means finishing some welding on the jeep tub. Hopefully I can have that knocked out this week.
"He used to be a pretty nice feller, now he's a welder!" |
Farm Truck
![]() Join Date: Aug 2006
Re: Custom Trailer Winch Mount
Good Idea.
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
Tot Roddin'
Love the winch plans.
What are the specs on the trailer? Mfg?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
MOVE OVER
I like that design.. nice looking trailer..
No matter where you are..... There you are... Buckaroo Banzi |
i mounted a reciever tube on the trailer and then mounted the winch on a plated welded to a piece of tube that fit the reciever this way I can take my winch off and put it on a truck or where ever i might need it
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
#6 | |
high-Tech Red Neck
I think I am going to upgrade it with a pair of 6000 lb axles so it can carry a bit heavier weight.
high-Tech Red Neck
Well here are some pics of it in the daylight.
![]() ![]() ![]() I loaded up my Jeep frame late last night so I could drag it over to the carwash today and get it cleaned up, it was so nice just being able to pull it right on with out fighting it or having to use a come along. ![]() ![]() Tomorrow I have a guy coming to buy my truck hopefully, if he does I am looking at picking up a 98 I found in Dallas that is also a crew cab dually but it is black and a 4x4.
high-Tech Red Neck
Lil video loading my jeep tub on the trailer with the winch to take it to the car wash.
https://www.youtube.com/watch?v=ELKV1d0uWfQ Worked out really super slick.
Tot Roddin'
Functioned quite well, nice work!
MOVE OVER
nice setup.. do you run it off a battery? or can it draw power from a RV hookup from the truck?
#11 | |
high-Tech Red Neck
I am also fixing to buy a Minnie Winnie, that will need to get wired up too for it. I am going to stick a v nose box on the front of the trailer and a battery box, as well as a spare tire mount. Lots of stuff to do. so little time! ![]()
