![]() Join Date: Nov 2010
WTB: Power steering pump pulley
I am in need if a power steering pulley for a 65 c10. Previous owner warped it pretty bad so I'm in need of one. Should be about the same for 60-67 years possibly later. Let me know what you have. Thamks
Posted via Mobile Device |
Re: Power steering pump pulley
truck shop in orange california has new pulleys and brackets
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
60-66 Nut
The short water pump was used up thru '72 in the trucks. So that will expand the year range of your search. It is possible that a long water pump power steering pump pulley may work. However there are 2 different styles of the pulley. The early ones had a keyway and were retained to the shaft with a nut. The later ones were a press fit onto the shaft.
Top
Here's what I need which seems to be Impossible to find
![]() Join Date: Apr 2003
whats the part number ?
part number is 3791943C1 GM
truck shop in orange cal.
painted ones are $37, chrome are $24
here is both
lower left and upper middle, sorry the text didnt copy only the images
Already tried it. Its different then the one I've got
I don't know why this is so damn hard to come by. Unless when he tried a puller on the pulley it pressed it in to make it look like that. But I doubt it did that much
Is this the number off your pulley? I have several pumps I will look at mine and see what the numbers are and if they have a different shape than yours.
#15 |
Yes that's the part number. Thanks
#16 |
at least one of mine have different numbers. I will look at more later
#17 |
Thanks for looking. I'm in desperate need if one
#18 |
Top
#19 |
Re: WTB: Power steering pump pulley
Heres one from a 64 pickup v8 with power steering.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
#20 |
That was the back, heres the side
#21 |
Heres the front
#22 |
Does that have the same parts number?
#23 |
Your 3791943 is a 6 cylinder power steering pulley. It is the exact thing i have however the v 8 pulley i have is a little smaller in diameter than yours and the v on mine is a little deeper for higher rpm's of a v8 compaired to a 6 cylinder. The # on mine is 3770509 can you post a pic of the pump set up on yours? Just wondering if its a mismatch of parts. Your pulley is the exact pulley my dad has on his 66 6 cylinder chevy nova.
#24 |
Well it came off a 63 3/4ton from the factory. I'm waiting to put the pump on until I have the pulley. Maybe the one I got like yours will line up?
#25 |
Send a pic of the pump and bracket, no way to tell if it is factory its almost 50 years old.
