Re: 14 bolt in a 68 longhorn?
Looks like a semi floater you can tell from the end of the axle and the pumpkin and yes they should be wider as mine was right at 3in wide/1.5in on each side although i had a full floater from an... 05 i believe
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
The ff axles make sense and I kind of wish I could find a decent one but I don't plan on wheeling it. It's just needed for towing the quads to the dunes and a little sand or dirt roads. I think the sf will work fine for my applications and budget. Now if only I can locate an 8 lug front axle to get the 4wd coversion started
![]() USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
The axle came with a surprise.
Posted via Mobile Device Posted via Mobile Device
Alright so next question. Master cylinder. I imagine with my 68 master cylinder it's going to push too much pressure to the discs and not enough to the front drums.. Probably causing the rear to lock up every time I hit the brake. Since I plan on putting discs up front could I use a 99 master with the 72 disc brakes or do I need to get a newer style caliper as well?
Or is there a company out there that thought of this already? Posted via Mobile Device
I found this. http://67-72chevytrucks.com/vboard/s...68&postcount=4 I might look into it for the front.
Oh look! A Gov-Bomb!
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
The gov bomb already went off lol. I could convert it to an open diff or get a truetrac. Anyone have one of those?
#8 | |
Trutracs are great. I ran one in the front of a 4x4 with a very healthy bigblock and 40" tires. I did break an axle one time, but the differential was fine, and that is way over what they are recommended to take.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
