Old 04-02-2013, 11:12 PM   #826
Hardesty454
Hardesty454's Avatar
Re: Shawno72's long overdue 68 daily driver build thread
You can come try on my 20's... They're 6 lug!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 04-02-2013, 11:19 PM   #827
shawno72
C/10 junkie
shawno72's Avatar
With the disc brake install and new rest axles I'm 5 lug now. Got any 5 luggers?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-02-2013, 11:23 PM   #828
Hardesty454
Not here, I'm going to be swapping over to 5 lug eventually. Not yet though.
Rob
Old 04-03-2013, 12:15 AM   #829
HotRod C/10
HotRod C/10's Avatar
I do, and you can get some real Mexican food while your here!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 04-03-2013, 12:20 AM   #830
shawno72
C/10 junkie
shawno72's Avatar
Hey I'm in California. The Mexican food is just as authentic here
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-03-2013, 12:30 AM   #831
HotRod C/10
ehh........I have had some descent stuff in San Diego, LODI is in the US?
LS SWAPPED
-1976 SILVERADO
Old 04-03-2013, 10:03 AM   #832
shawno72
C/10 junkie
shawno72's Avatar
Yes Lodi is filled with good Mexican food places, some you have to be able to order in spanish.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-03-2013, 10:06 AM   #833
shawno72
C/10 junkie
shawno72's Avatar
Ok so the shrader set up for the rear bags is gonna be temporary and I didn't want to mount the fill valves anywhere with permanent holes. I thought about zip ties but then I said wait I know where they would be almost undetectable. I'm sure this has been done before but it works for me
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-03-2013, 10:30 AM   #834
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Hey Shawn, Better get to DMV your tags about to expire
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-03-2013, 10:41 AM   #835
shawno72
C/10 junkie
shawno72's Avatar
Haha yeah I got till the 30th
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-03-2013, 02:26 PM   #836
Bennett68C10
Bennett68C10's Avatar
Nice Shawn, I like how you mounted the schrader valves.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-03-2013, 06:18 PM   #837
knomadd
knomadd's Avatar
Hey Shawno, did you ever figure out what's up with your brakes? I had a similar issue when I swapped my drum brakes in my GTO over to discs. I installed an SSBC front disc conversion kit and it wouldn't stop as well as my stock drums.
I wound up calling SSBC to get some tech support and they sent me a new booster thinking it was bad. When that didn't work, they thought my MC bore was too big/small. (Sorry, I can't remember which one since it was over 8 years ago. I don't want to guess and make your situation worse, so I'll leave that to someone else, but see if you can get some info from brake people on what a different bore size will do.) Even put in an electric vacuum pump because they thought I didn't have enough vacuum to run the power booster (sent that $#!+ back to them 'cause it didn't do anything but shake the car and made a lot of noise).
Eventually I went with a Hydratech hydro booster. I loved it so much, I ordered one for the C/10 too. Haven't installed it on the C/10 yet but I still think my factory discs don't stop as well as the drums on the Goat did. It might be that I only have about 10" of vacuum (5 at idle) and "you need 20+ for discs to work properly" according to SSBC.
Good luck!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-03-2013, 06:27 PM   #838
shawno72
C/10 junkie
shawno72's Avatar
Good luck!
Thanks for asking Duane, I just came in from changing the master to the 1 1/8" bore and the brake pedal is worse. I am going to just ride it for a bit cause it feels like the brake pads aren't stopping the truck. When I mash the pedal down as hard as I can the truck stops but just felt so much better with the stock drums. I kinda at the point where I don't want to over think it so I'm just gonna roll it for a bit and see what happens
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-04-2013, 09:23 AM   #839
shawno72
C/10 junkie
shawno72's Avatar
Ok I bit the bullet and ordered a new aluminum master and new aluminum prop valve. The booster has a lifetime warranty on it through Oreillys so I will warranty it out at the same time I swap these parts in. I'll let you guys know how it turns out.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-04-2013, 09:34 AM   #840
fastcam1
Young gun
fastcam1's Avatar
Attachment 1086537
Nice shrader location! Looks clean keep it up
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 04-04-2013, 09:40 AM   #841
shawno72
C/10 junkie
shawno72's Avatar
Thanks man. I plan to install the bags in 2 more days!!
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-04-2013, 10:09 AM   #842
big_al_71
big_al_71's Avatar
Love the idea of where the shrader valves are mounted....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-04-2013, 10:24 AM   #843
Low Elco
Might check the location of where your rod is hooked to the brake pedal. One gives more leverage. There are 2 holes on some trucks, switch it and try.
Low Elco is offline   Reply With Quote
Old 04-04-2013, 11:00 AM   #844
shawno72
C/10 junkie
shawno72's Avatar
Thanks Al, will serve the purpose and look clean.
Oh man I hope its that simple
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-04-2013, 11:55 AM   #845
lolife99
67-72 parts collector,…
lolife99's Avatar
Here's some internet instructions on seating brake pads and rotors.
It's worth a shot,...
Caution: When you've just installed new pads/rotors or a big brake kit, the first few applications of the brake pedal will result in almost no braking power. Gently apply the brakes a few times at low speed in order to build up some grip before blasting down the road at high speed. Otherwise, you may be in for a nasty surprise the first time you hit the brakes at 60 mph.
When following these instructions, please avoid doing it in the presence of other vehicles. Breaking in your new pads and rotors is often best done very early in the morning, since other drivers will have no idea what you are up to and will respond in a variety of ways ranging from fear to curiosity to aggression. And an officer of the law will probably not understand when you try to explain why you were driving erratically! Zeckhausen Racing does not endorse speeding on public roads and takes no responsibility for any injuries or tickets you may receive while following these instructions.
From a speed of about 60mph, gently apply the brakes to slow the car down to about 45mph, then accelerate back up to 60mph and repeat. Do this about four or five times to bring the brakes up to operating temperature. This prevents you from thermally shocking the rotors and pads in the next steps.
Make a series of eight near-stops from 60 to about 10 mph. Do it HARD by pressing on the brakes firmly, just shy of locking the wheels or engaging ABS. At the end of each slowdown, immediately accelerate back to 60mph. DO NOT COME TO A COMPLETE STOP! (Note: With less aggressive street pads and/or stock brake calipers, you may need to do this fewer times. If your pedal gets soft or you feel the brakes going away, then you've done enough. Proceed to the next step.)
During this process, you must not come to a complete stop because you will transfer (imprint) pad material onto the hot rotors, which can lead to vibration, uneven braking, and could even ruin the rotors.
Depending on the pads you are using, the brakes may begin to fade slightly after the 7th or 8th near-stop. This fade will stabilize, but not completely go away until the brakes have fully cooled. A bad smell from the brakes, and even some smoke, is normal.
After the 8th near-stop, accelerate back up to speed and drive around for as long as possible without using the brakes. The brakes will need at least 10 minutes to cool down. Obviously, it's OK to use the brakes to avoid an accident, but try to minimize their use until they have cooled.
If club race pads, such as Pagid Orange or Porterfield R4, are being used, add four near-stops from 80 to 10mph. If full race pads, such as Pagid Black, are being used, add four near-stops from 100 to 10 mph.
After the break-in cycle, there should be a blue tint and a light gray film on the rotor face. The blue tint tells you the rotor has reached break-in temperature and the gray film is pad material starting to transfer onto the rotor face. This is what you are looking for. The best braking occurs when there is an even layer of of pad material deposited across the face of the rotors. This minimizes squealing, increases braking torque, and maximizes pad and rotor life.
After the first break in cycle shown above, the brakes may still not be fully broken in. A second bed-in cycle, AFTER the brakes have cooled down fully from the first cycle, may be necessary before the brakes really start to perform well. If you've just installed a big brake kit, the pedal travel may not feel as firm as you expected. After the second cycle, the pedal will become noticeably firmer. "
Keith
Convert to disc brakes.
Old 04-04-2013, 12:04 PM   #846
shawno72
C/10 junkie
shawno72's Avatar
Thanks Keith, I'll give that a try.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-05-2013, 10:40 AM   #847
shawno72
C/10 junkie
shawno72's Avatar
Well I came in early to work this morining to install the rear air bags. Very easy install and with it aired out the pumpkin does bottom out on the bed floor. First pic of the truck is before, second is aired out and third is set a ride height which is identical to the before measurement.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-05-2013, 10:44 AM   #848
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Nice start to the day!
Zoomin is offline   Reply With Quote
Old 04-05-2013, 10:48 AM   #849
shawno72
C/10 junkie
shawno72's Avatar
Agreed!! Now if I only had a tank and compressor.........
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-05-2013, 10:57 AM   #850
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Yup!
And then you're going to want some valves. Then controls...
Always something!
