Old 03-30-2013, 09:43 AM   #1
Hart_Rod
Hart_Rod's Avatar
New speedometer cable and rear rubber brake lines
I bought a new speedo cable from GMC Pauls for my 68 C10, but I will no longer need it since I'm upgrading my transmission to 6L80e. $27.50 shipped
I also have a set of new rubber brake lines for a rear disck setup. They come with the banjo bolts and copper O rings. $30 shipped
Hart_Rod is offline   Reply With Quote
Old 04-03-2013, 01:52 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: New speedometer cable and rear rubber brake lines
ttt
Old 04-03-2013, 04:11 PM   #3
gdavis
gdavis's Avatar
What is the difference between th hose? For the front verses the rear? They look the same. Are the front longer than the rear?
gdavis is offline   Reply With Quote
Old 04-03-2013, 04:58 PM   #4
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
Do you think the speedo cable will work for a 700R4? I am in the process of removing my SM465 and putting in a 700R4 in my '72 Jimmy with a 350.
Thank you,
Bob
Sandemonium is offline   Reply With Quote
Old 04-03-2013, 05:18 PM   #5
Hart_Rod
Hart_Rod's Avatar
I'm not sure. These are 11" long if that helps.
Thank you,
Bob
I think it will work on all of the transmissions.
Old 04-05-2013, 08:13 AM   #6
Hart_Rod
Hart_Rod's Avatar
bump
Old 04-05-2013, 08:31 AM   #7
HotRod C/10
HotRod C/10's Avatar
Ill take the speedo cable
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 04-05-2013, 08:51 AM   #8
Hart_Rod
Hart_Rod's Avatar
Sweet! You can just buy the headers and I'll throw the speedo in for free..... Let me know if you need the paypal info again. Thanks,
Old 04-05-2013, 02:16 PM   #9
HotRod C/10
LOL...........You still have the?!!............Send it again and I will get you paid.
Thanks again
David
LS SWAPPED
-1976 SILVERADO
Old 04-05-2013, 02:51 PM   #10
HotRod C/10
Sweet! You can just buy the speedo cable and I'll throw the Headers in for free..... Let me know if you need the paypal info again. Thanks,
Fixed it for ya
PP sent
LS SWAPPED
-1976 SILVERADO
Old 05-11-2013, 09:33 AM   #11
Hart_Rod
Hart_Rod's Avatar
brake lines still available...
Old 05-11-2013, 11:08 AM   #12
tjmeadows
Would you accept $20 for the brake lines shipped?
tjmeadows is offline   Reply With Quote
Old 05-11-2013, 11:51 AM   #13
Hart_Rod
Hart_Rod's Avatar
How about meet in the middle at $25?
