Old 04-03-2013, 10:48 PM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
removing axles
first time removing axles from my 66 c10,getting drilled from 6 lug to 5?any suggestions?
1966FLEETSIDE is offline   Reply With Quote
Old 04-03-2013, 11:08 PM   #2
Reyals Bemus
Re: removing axles
Remove wheels, remove drums, pop rear diff cover, drain oil, remove cross shaft pin bolt, remove cross shaft, tap axles inward just enough to allow c-clips to drop out, then pull axles out.
Reyals Bemus is offline   Reply With Quote
Old 04-04-2013, 12:11 AM   #3
1966FLEETSIDE
Re: removing axles
awsome thanks.im still debating wether i should get them drilled out.or just doing the conversion swap.
Old 04-04-2013, 12:22 AM   #4
donthekawguy
donthekawguy's Avatar
Re: removing axles
While you have them out you might as well change the seals and maybe the bearings.
66 shorty
donthekawguy is offline   Reply With Quote
Old 04-04-2013, 07:48 AM   #5
tincan1966
tincan1966's Avatar
Re: removing axles
Most importantly, DO NOT rotate the differential gears(turn the driveshaft) once the cross pin is removed. If you do, you will have to realign the spider gears. It's not disastrous, but time consuming and frustrating.
tincan1966 is offline   Reply With Quote
Old 04-06-2013, 01:46 AM   #6
1966FLEETSIDE
Re: removing axles
thax for the great tips fellas
Old 04-06-2013, 02:40 PM   #7
65chevysub
65chevysub's Avatar
Re: removing axles
I had the original axles on my 65 Suburban re-drilled to a 5 lug patter by Moser in the mid 90's. Simple enough process, just take your time.
65chevysub is offline   Reply With Quote
Old 04-16-2013, 12:14 AM   #8
1966FLEETSIDE
Re: removing axles
should seals and bearings be changed if they look so..so
Old 04-16-2013, 12:17 AM   #9
1966FLEETSIDE
Re: removing axles
finally got my axels back from cooks machine works in e.l.a.drilled to 5on5,cant wait to slap them on.yaaay
Old 04-16-2013, 07:24 PM   #10
donthekawguy
Re: removing axles
I would change the seals just because you have the axles out and they are cheap.
66 shorty
Old 04-16-2013, 08:00 PM   #11
gofastnut
gofastnut's Avatar
Re: removing axles
X2
Ounce of prevention and all that...
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
