Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-23-2013, 05:33 PM   #1
dtkarst
WTB: Power steering pump pulley
I am in need if a power steering pulley for a 65 c10. Previous owner warped it pretty bad so I'm in need of one. Should be about the same for 60-67 years possibly later. Let me know what you have. Thamks
dtkarst is offline   Reply With Quote
Old 03-23-2013, 08:22 PM   #2
sigshooter
sigshooter's Avatar
Re: Power steering pump pulley
truck shop in orange california has new pulleys and brackets
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 03-23-2013, 10:54 PM   #3
Captainfab
60-66 Nut
The short water pump was used up thru '72 in the trucks. So that will expand the year range of your search. It is possible that a long water pump power steering pump pulley may work. However there are 2 different styles of the pulley. The early ones had a keyway and were retained to the shaft with a nut. The later ones were a press fit onto the shaft.
Old 04-01-2013, 04:21 PM   #4
dtkarst
Top
Old 04-01-2013, 09:53 PM   #5
dtkarst
Here's what I need which seems to be Impossible to find
Old 04-01-2013, 09:58 PM   #6
dtkarst
Old 04-01-2013, 11:09 PM   #7
southern parts
southern parts's Avatar
whats the part number ?
southern parts is offline   Reply With Quote
Old 04-01-2013, 11:25 PM   #8
dtkarst
part number is 3791943C1 GM
Old 04-02-2013, 07:45 AM   #9
sigshooter
sigshooter's Avatar
truck shop in orange cal.
painted ones are $37, chrome are $24
1966 Short stepside
1964 long bed
Old 04-02-2013, 11:09 AM   #10
sigshooter
sigshooter's Avatar
here is both
1966 Short stepside
1964 long bed
Old 04-02-2013, 11:11 AM   #11
sigshooter
sigshooter's Avatar
lower left and upper middle, sorry the text didnt copy only the images
1966 Short stepside
1964 long bed
Old 04-02-2013, 12:18 PM   #12
dtkarst
Already tried it. Its different then the one I've got
Old 04-02-2013, 12:30 PM   #13
dtkarst
I don't know why this is so damn hard to come by. Unless when he tried a puller on the pulley it pressed it in to make it look like that. But I doubt it did that much
Old 04-02-2013, 12:47 PM   #14
sigshooter
sigshooter's Avatar
Is this the number off your pulley? I have several pumps I will look at mine and see what the numbers are and if they have a different shape than yours.
1966 Short stepside
1964 long bed
Old 04-02-2013, 12:50 PM   #15
dtkarst
Yes that's the part number. Thanks
Old 04-02-2013, 06:54 PM   #16
sigshooter
sigshooter's Avatar
at least one of mine have different numbers. I will look at more later
1966 Short stepside
1964 long bed
Old 04-03-2013, 09:03 AM   #17
dtkarst
Thanks for looking. I'm in desperate need if one
Old 04-04-2013, 08:41 AM   #18
dtkarst
Top
Old 04-04-2013, 03:00 PM   #19
BIG V
Re: WTB: Power steering pump pulley
Heres one from a 64 pickup v8 with power steering.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 04-04-2013, 03:01 PM   #20
BIG V
That was the back, heres the side
Old 04-04-2013, 03:08 PM   #21
BIG V
Heres the front
Old 04-04-2013, 04:17 PM   #22
dtkarst
Does that have the same parts number?
Old 04-04-2013, 05:05 PM   #23
BIG V
Your 3791943 is a 6 cylinder power steering pulley. It is the exact thing i have however the v 8 pulley i have is a little smaller in diameter than yours and the v on mine is a little deeper for higher rpm's of a v8 compaired to a 6 cylinder. The # on mine is 3770509 can you post a pic of the pump set up on yours? Just wondering if its a mismatch of parts. Your pulley is the exact pulley my dad has on his 66 6 cylinder chevy nova.
Old 04-04-2013, 11:04 PM   #24
dtkarst
Well it came off a 63 3/4ton from the factory. I'm waiting to put the pump on until I have the pulley. Maybe the one I got like yours will line up?
Old 04-04-2013, 11:23 PM   #25
BIG V
Send a pic of the pump and bracket, no way to tell if it is factory its almost 50 years old.
