Old 04-03-2013, 10:06 AM   #1
carlisle72
cluster lights not working?
hello,
just replaced the circuit board for my instrument cluster. gauges are working but none of the bulbs. tested and have power in wire harness going to the cluster but no lights working? Any suggestions to what to look for? oh, old one was working but looked really worn, so i replaced it. should have left well enough alone. i even put the old one back on same problem.
1972 chevy
thanks
ps check fuses look good
carlisle72 is offline   Reply With Quote
Old 04-03-2013, 10:10 AM   #2
Longhorn 70
Longhorn 70's Avatar
Re: cluster lights not working?
Headlight switch? Fuse?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 04-03-2013, 10:12 AM   #3
shawno72
C/10 junkie
shawno72's Avatar
Probably one of the bulb holders isnt seated right. Make sure you ground the circuit board to the rear tin. My new circuit board wasn't missing the hole for the screw like my original one had.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-03-2013, 10:31 AM   #4
carlisle72
headlight switch is new, fuses look good. the new circuit board had all the same screws the old one had. is there a way i need to ground the circuit boad to the tin?
Old 04-03-2013, 10:42 AM   #5
shawno72
C/10 junkie
shawno72's Avatar
Only with the screws from the old one.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-03-2013, 11:07 AM   #6
AirSpeed
AirSpeed's Avatar
Have you tried turning the headlight knob? Maybe the dimmer is turned off, try turning the knob all the way.
AirSpeed is offline   Reply With Quote
Old 04-03-2013, 11:47 AM   #7
carlisle72
yeah dimmer is not off. hazard lights/flashers won't light up either. i've tested with my test light and i've got power on the circuit board at the bulb, like at the hazard lights, test lights up everytime it blinks but bulbs not lighting. seems like it could be a grounding issue, but i can't figure it out.
Old 04-03-2013, 11:52 AM   #8
Longhorn 70
for grins clip your test light to ground and the probe end to a metal spot on the cluster.... see what changes or if the test light glows..
Old 04-03-2013, 12:01 PM   #9
carlisle72
i just ran the test light to the ground side and nothing, it didn't light and the bulb didn't light either. i'm so lost and aggravated with this.
Old 04-03-2013, 12:16 PM   #10
Longhorn 70
I am betting that if you did the probe between a ground and the metal on the panel and nothing lit, grounds aren't your problem.
If you had a bad ground and had the lights on and connected that way, you'd see a glow in the test light filament as there would be a difference in potential. If you have a volt meter you can verify that too... Red to panel ground and black to good chassis ground. You should see just a few millivolts. There should be a black 18 ga. wire on the panel that is ground too.
I'd still check the light switch...........for grins.
Old 04-03-2013, 03:15 PM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
With the light switch on check for 12 volts on each end of the panel lights fuse in the fuse panel. Make sure the headlight switch knob is fully on bright.
If you get 12 volts there then check the gray wires on the cluster plug on terminal 8 for 12 volts or bright test light.
If you get 12 volts there then check for 12 volts between the gray wires and the black wire on terminal 7. This is the ground wire to the cluster. If you get these numbers then the power feeds to the cluster are ok and Your circuit board and cluster are probably not grounded.
look at the picture and just to the left of the cluster plug in you can see a small screw. This grounds the circuit board to the cluster and then you have to ground the cluster to the cab at a good ground for the lights and gauges to work. There is another one that is just above the speedometer on the right as well.
Here is the wiring to the gauge style cluster plug.
Name:  cluster connector with gauges.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-03-2013, 03:23 PM   #12
wgr2112
Is the back panel of the cluster painted? Shouldn't be an issue but the paint MAY prevent good metal to metal contact.
Just a thought.
wgr2112 is offline   Reply With Quote
Old 04-03-2013, 06:08 PM   #13
carlisle72
Attachment 1086624
Attachment 1086625
don't have a volt meter yet. i did use the test light and got a good light at the panel fuse and the gray wires. not quite sure what you mean about between the gray wires and the black ground wire. nothing on test light on the ground wire. have a ground wire running from housing to clean ground and still nothing.
Old 04-03-2013, 06:40 PM   #14
slikside
slikside's Avatar
Subscribed.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
Old 04-03-2013, 07:16 PM   #15
tsali39
tsali39's Avatar
Same problem here. I have two lights ( speedo ) but no lights at the gas gauge. I am about to led the whole unit and be done with it!
Eddie
tsali39 is offline   Reply With Quote
Old 04-03-2013, 10:32 PM   #16
VetteVet
Msgt USAF Ret
VetteVet's Avatar
If you look at the second picture in my post above You can see the gray wires and the black wire in the cluster plug. You can check power on the gray wires with your test light by going between the gray wires and any ground, with the headlight switch on.
There are no lights for the fuel gauge. It gets it's light from the 2 lights on each side of the gauge in the cluster. The two lights below the gauge are for the temp light and the brake warning light which have their own power sources.
Here is another diagram of the circuit board. The orange wires are the grounds for the dash lights and the gray wires are the power wires.Notice that the gray wires go to no.8 on the terminal connector and the grounds go to no.7
These are the two points I was talking about checking for 12 volts on the plug.
Name:  Dash  Layout Final.jpg
VetteVet
Old 04-03-2013, 11:53 PM   #17
carlisle72
yeah i got power at the points you stated. when using my test light i used the black wire as a ground and tested the gray wires and got a light, so it seems the black ground wire is grounded.
Old 04-04-2013, 01:40 AM   #18
VetteVet
Msgt USAF Ret
VetteVet's Avatar
If you've got power at the cluster plug on the gray wire then the only thing left is the plug and pins on the cluster. Unless the lights are all bad or their sockets are not making contact with the circuit board. If your gauges are working then the cluster is grounded so the power pin must not be making good contact. VV
VetteVet
Old 04-04-2013, 11:56 AM   #19
carlisle72
thanks longhorn and vettevet for all your help. a word to the wise, if you ever replace your light sockets on your instrument cluster make sure the connectors are not totally laying flat. hahaha, after all that work and testing stuff and tearing into everything the connectors on the sockets were not bent upwards and making connection to the circuit board. but i learned a few things about chevy instrument clusters and tearing into a dash so atleast i learned something. thanks again guys.
Paul
Old 04-04-2013, 12:23 PM   #20
Longhorn 70
Good job Paul! Glad you got them going.
Old 04-04-2013, 12:48 PM   #21
wgr2112
Good to know!
I have a large pile of bulbs and sockets. I've tested all of them and they can be finicky about the way the bulb sits in the socket as well.
Old 04-04-2013, 04:56 PM   #22
dirish
dirish's Avatar
I learned alot!
dirish is offline   Reply With Quote
Old 04-04-2013, 05:13 PM   #23
Longhorn 70
Just for grins I was going to add this image but since it was solved.....
It may help some to get LED lights to work. I made it for my reference. I marked polarity on it in thoughts of making my own LED bulbs. I didn't think they'd be as cheap as they are on eBay. Go figure..... Here it is.
