Old 04-05-2013, 10:05 AM   #1
60-66
60-66's Avatar
Re: 230 or 250?
Originally Posted by MyNewFoundGlory View Post
I realize all the components are mostly, if not all, interchangeable between the 230 and 250. But this is just for my knowledge and ego. Can someone help me differentiate between the two. I've check many threads and found the engine was made in Canada and the month and year but im lost on the "ST" meaning. Please help!
Attach: the stamped #'s
The ST suffix shows up as it was in a "P10" VAN? 230 Cu In for 1966 and 1967 . ST code was not used in 1965 or 1968.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-05-2013, 10:17 AM   #2
MyNewFoundGlory
MyNewFoundGlory's Avatar
Re: 230 or 250?
So you're saying it is a 230? Yea I was told the motor was replaced once before in the 70's but I figured it was a direct replacement, not a different vehicle type. Thanks 60-66
Steve
1964 C10 I6 StepSide
2012 Cruze RS 1.4T
MyNewFoundGlory is offline   Reply With Quote
