Re: Traction Problems/Time slip
I have no clue what the gears are. I got the transmission off of craigslist and the rear end is a stock posi. As for the slicks I ran, I have no idea what size they were. They were on a 15x10 rim. They seemed pretty tall, but I could just be seeing things. The tires I ran myself, I don't know off the top of my head. I will take a look. They are pretty small.
#2 | |
It's Better With Nitro
I would bet the Caddy is making over 400 ft-lbs off idle, so I would just leave off idle in the meantime. Assuming you were at Firebird, what was the dew point and how was it prepped?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 04-09-2013 at 08:02 PM. |
#3 | ||
If I do end up getting a TH400, would it be best to have a shift kit in it or not? Also, it was a pretty decent out that weekend and I don't know how they prep it. Quote:
Also, I'm not so sure about the whole weight thing. These motors weigh less than a 454. With this caddy in my truck, my front end actually sits a tad higher than the rear. But then again, the rear springs could be worn out. I'll try to find some friends that have scales and see if I can get the weight of the front and the rear and compare them. |
Keep in mind that if you are able to make this truck hook, it wont be long for life on that stock drive train. The weakest link will pop... Unless you plan on replacing the trans, drive shaft, u joints, rear end, etc in short order, it may be a better idea to simply let it slip a bit. Feathering the throttle out of the holeshot always worked well for me on street tires.
Impressive times, though! I'd love to see pics.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
#5 | |
