Old 04-05-2013, 07:46 PM   #1
Erl
Erl's Avatar
Master Cyl to Proportion Valve Tubing
I have a 68 3/4 ton 4x4 that now has a disk brake front end. I am using a 72 master cylinder, proportion valve and brake booster. My question is how should the tubes from the master cylinder to the proportion valve be connected. I have attached two different photos showing the difference.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 04-05-2013, 08:03 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Master Cyl to Proportion Valve Tubing
I just got through with my 3/4 disc conversion and installed the M/C and proportioning valve. According to the instructions I received, it should look like this. Keep in mind this isn't stock and is a disc conversion on a 70.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 04-05-2013, 08:15 PM   #3
john
member #16
john's Avatar
Top pic looks correct for a 3/4 ton, for some reason they were opposite on 1/2 tons. front to front and rear to rear on halfs.
john is offline   Reply With Quote
Old 04-05-2013, 10:01 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Here is mine for a 1972 Cheyenne 1/2 ton 2wd.
TBONE1964 is offline   Reply With Quote
Old 04-05-2013, 10:28 PM   #5
71K20chevy
71K20chevy's Avatar
Here's my '71 K20
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 04-06-2013, 12:11 PM   #6
Erl
Erl's Avatar
71K20chevy your setup looks original. Is that the case?
I had ordered new stainless tubes from Inline Tube and they look like yours. I had not seen that configuration before.
Dallas TX
Old 04-06-2013, 09:03 PM   #7
71K20chevy
71K20chevy's Avatar
Yes they are.
71 K20
64 GMC mud truck
