Old 04-07-2013, 09:01 AM   #1
wraprail
wraprail's Avatar
Re: need more lower!!
X2 on the Z. If you are changing the frame out anyways then you are half way there. I didn't know what I was doing and mine came out *****en. If you have a welder and a grinder you are set.
One more thing that is usually overlooked. Go with a larger wheel. At least 18 or 20 even better. When you start lowering alot with 15 inch wheels it don't take much and you are below the bottom of the rims. Very unsafe. I was shocked at the change in clearance just going to a 20 inch rim. And so much safer should you have a tire blow.
Just my2 cents
wraprail is offline   Reply With Quote
