Re: What did you do to your truck today!
I installed the new rear bumper, added the LED taillights to it, installed antenna delete setup for internal powered antenna, and installed the new gas magnum shocks
temporarly put the cab back on the frame today reinstalled and alinged the doors then test fitted the rockers and corners the pilot/alignment holes i drilled in the hinges worked flawlessly as the doors fell right into place....man i forgot how heavy the doors are
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Here is the pics of the new rear bumper with the LED's mounted......looks a lot better than the cheesy homemade roll pan the Orig Owner built.
